#41 | |
Liked 799 Times in 236 Posts
"That'll never work....." |
#44 | |
Liked 53 Times in 16 Posts
Is this a actual old stocker cam you show..another words those old cams had square lobes too? The cam in my 396/325 is square lobe..but has more duration built into it, right? Did they also change the LSA, lobe separation angle of the race cam compared to the stock cam too? More overlap for higher RPM? Thanks for the lesson! I think it makes more sense to me. Will Lamprecht 65 Imp... |
#45 |
Liked 783 Times in 195 Posts
Maybe not more measured duration from open to close, but more "effective duration" due to opening the valve quicker and closing slower so that the valve is further off the seat for a longer period of time and thus allows more air to flow. "Area under the curve"
#46 |
Liked 231 Times in 107 Posts
Hasn't been a flat tappet motor produced in 20 yrs or more but still the flat tappet racer wants to have a dis-advantage over the newer cars. SMH
#47 | |
Liked 5,139 Times in 1,962 Posts
It's hard to compare those specs to .."@ .050, today, because that term was not part of the mix.
#48 | |
Liked 165 Times in 59 Posts
#49 |
Liked 7 Times in 6 Posts
Impstocker-you have a PM
#50 |
Liked 21 Times in 8 Posts
I’m not opposed to roller cams in stock and some cars already have them, NHRA has given everything else like a super stocker in stock and in my opinion there is no hp advantage or durability advantage. I also have never had a single valve train problem with my Hemi. It’s not the roller lifter that allows the working rpm range it’s the cam profile.
New billet steel cam $1000 , proper flat tappet lifter for said cam $850 , new set of push rods $400 , about the same price as the roller. If I’m going to upgrade from a cast cam I’d prefer the roller( not that we can have it). I’d also like to eventually run my cam/car through the traps at 85-8600 not so sure we will ever get there with the flat tappet stuff. 20+ years ago I wrote a letter to Nhra asking for roller cams , roller rockers , better springs, aftermarket rods , aftermarket brakes etc... with my opinion why we should do it. I never got an answer but eventually everything except the roller cams has come to pass. I get it Billy And Todd both like the little of what’s left , the purity of stock racing but it has moved so far away who really gives a **** anymore? $3500 stainless headers $6500 transmissions, $5000 torque converters ? Some stocker engines are approaching $30000. not much STOCK anymore for a long time now! This argument has been going on since 1987 when the cam rules changed and it has not gone backward since. |
