#21 |
Liked 61 Times in 22 Posts
Then I guess I have on the same horse blinders as you do.
#22 |
Liked 125 Times in 40 Posts
Did you consult with NHRA before you put them on?
Sean Cour T6066 ladle |
#23 | |
I've read the rule book on SS auto transmissions and I don't see why a "fluid dump" would be illegal. If you want to start splitting hairs then in reality a transbrake is a "fluid dump" and for that matter, so is an E-shift. NHRA seems much more concerned as to how you're releasing that transbrake then what you're doing with your pump pressure. Now if you are in some way manipulating your pump pressure to cause some kind of a "delay" in your transbrake release then I would think that you're doing something illegal. Just my $.02.
#24 |
#25 | |
Liked 1,063 Times in 376 Posts
If you look at a 1970 rulebook, you won't find sections on vacuum pumps, delay boxes, nitrous oxide, digital recorders, tranny brakes and the long throw buttons, blinders. Even radial tires was a huge step forward. Do you think that every single person that came up with these items (and tons and tons more), were "cheating"? IMO they were just using the rules in place to further their advantage. Eventually, new rules were written to regulate most of them. But they didn't let it go YEARS before implementing new rules. That's the thing here, there's a lot of money laying on the table. Good Lord, you built one yourself right? There's more of these engines out there than anyone's thinking. From multiple engine builders. I've had phone calls from two racers that are in the same boat as the minions camp.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 12-28-2019 at 07:03 PM. |
#26 |
Liked 8,213 Times in 1,536 Posts
#27 | |
Only two rules for S/S automatic transmissions. (Maybe this is three) 1a, Must be from the same parent company 1b, Must bolt to to engine block without an adapter. 2, No centrifugal lock up converter ..i.e , the Griner / Coan unit from 40 years ago. If some tech person told anyone that they couldn't the fluid path internally, then you probably should have never asked.
#28 |
Liked 239 Times in 90 Posts
I agree with all of you. I don't care if the valve is legal or not. I just know that NHRA likes the grey areas to fall on their side of their fence. Hence when they say "if it doesn't say you CAN, then you Can't" . I installed an onboard air compressor system in my stocker(cause i'm horrible at checking tire pressure lol). It doesn't say in the rule book that I CAN have one, nor does it say that I can't have one, but I was told NO in stock, superstock ok but not Stock. GREY area, no specific wording against but also no wording saying its allowed.
#29 | |
#30 | |
Liked 231 Times in 107 Posts
