Liked 503 Times in 131 Posts
I put LED headlight bulbs in the trusty 08 4runner and its night and day, what a difference. Snagged some for the rest of the street fleet. Did the wife's camry the other night.
Anyone do LED bulbs in their RV? Figuring out what you have for lights in your coach isn't that easy, for my vectra they used 2005 mercury mountaineer headlights took a bit of internet sleuthing to figure that out, snagged some LED 9007's for the Vectra which will fit. Hope they work as well as in the 4runner, the stock 9007 is very weak especially on low beam, its not too bad on high. Will post back once I get it done, likely will not be till Spring. Eric
Eric Merryfield 1883 STK |
Liked 472 Times in 72 Posts
I need to change the high beam in our 2019 Seneca. The low beams are ok but high beam arnt much better than the low. We are on a Jayco Seneca sight and a few have changed the whole headlight setup to LED,but they were alot of $$$. Something I should put on my list to do for next year. Thanks for bringing it up.
#3 | |
Have noticed that due to the cooling fan, the FM reception for some stations isn't as good, may need a capacitor to block the noise, motorhome at Cummins, it may be coming home this week, and I will not be worrying about radio reception with the lights on, its terrible in the pits trying to tune in the track .........goldrush trailer radio perfect everytime.... Eric
7Hi Eric,,I found out that alot of my fellow Jayco Seneca owners are going to Opt7 Fluxbeam X headlight bulbs. For us they are around $110 a set for high beam or low beam. We are going to start with low beam first.
Guest
Posts: n/a
I also upgraded to LED bulbs in my RV, and it made a big difference. It's awesome that they worked well in your 4Runner too. LED 9007s should be a good choice for the Vectra. Looking forward to hearing how they perform in your RV in the spring.
