Old 12-12-2019, 04:23 PM   #1
davidhuff
Liked 120 Times in 42 Posts
Default How Much Does Density Altitude Affect ET
I know very little about Density Altitude and was searching for information.
Old 12-12-2019, 05:21 PM   #2
Dustin Ward
Liked 4 Times in 2 Posts
Default Re: How Much Does Density Altitude Affect ET
Give this a read. Your results may vary.
https://www.biondoracing.com/tips.shtml
Dustin Ward is offline   Reply With Quote
Old 12-12-2019, 05:45 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
My understanding that 1 and 2 barrels swing wider than 4 barrels and low compression wider than high compression and a stock converter (sportsman bracket) wider than a high flash converter, etc, etc, etc, etc . The really good cars may change very little with the weather.
Dave Noll, EF/S ,?/SA 6526
Old 12-12-2019, 06:19 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
While I’ve always referenced Biondo’s tips as a guide I would just point out that meticulously keeping notes on all your runs is invaluable to setting up a reliable correlation curve between DA and ET since the host of other variables (i.e. wind) can play such a huge role. I’m just now trying to explore some of the analytics of this and discover that my last year’s record keeping was painfully inadequate. You can probably guess one of my New Year’s resolutions.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-12-2019, 08:24 PM   #5
Ralph A Powell
Liked 226 Times in 137 Posts
Percent of oxygen changes can have a big impact and since very few measure this the basic numbers can remain the same but the percentage of oxygen can change and have a large impact!
Old 12-12-2019, 08:32 PM   #6
Keith 944
Keith 944's Avatar
On my two cars basically 200 feet of altitude change equals one hundred .01 I run them a little fat so that it will be this way
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 12-12-2019, 10:17 PM   #7
Jeff Stout
Liked 706 Times in 283 Posts
That's pretty good. Im 145ft of change and. 1 ET difference. I run mine just right in the heat then when air gets good car goes lean. That gets me the 145ft average
Old 12-13-2019, 12:29 AM   #8
cmracing
Liked 62 Times in 29 Posts
My faster car is about .01 per 300ft running on race gas.
cmracing is offline   Reply With Quote
Old 12-13-2019, 10:19 AM   #9
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
My experience has been that if you run around the ideal air/fuel ratio you will see 150 ft equals .01. Or you can run lean and move higher into the 200ft area. It gets hairy as you get leaner and can do engine damage. The only time that I've seen the 300ft range is with ethanol in our bracket car. A normal ethanol car will equal the 300ft per .01 area. If you don't see these numbers or if your car isn't consistent , you probably have a problem that needs correcting.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 12-13-2019, 11:21 AM   #10
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
I've been strongly suspecting for a while that this is the case. When I stay near home I can get a pretty good idea from DA and wind but then I go to a different area, where they have those weird tall things (I think they call them trees) and suddenly I'm way off in my dial-in.
Dave Muller is offline   Reply With Quote
