#51 |
#52 |
One interesting fact is that as discussed earlier, one of the first users of intake manifold adapters in the 1970's was Ed Hamburger on his Mopar 340 and 360 Super Stock engines. The adapter allowed Ed to use a SBC intake. Therefore, since the 1970's NHRA has been allowing spacers and adapters in Super Stock class.
As a matter of fact the Ed Hamburger and Bruce Bachelder (former NHRA Tech Rep) Mopar used the adapter with the SBC intake until Offenhauser came out with the SBM Port-O-Sonic intake. |
#53 |
Liked 204 Times in 54 Posts
This is a silly rule and that's being kind.
If the concern is the intake side of the head then make changes to head rule or maybe enforce the current rules. Prohibit spacers? You have to wonder who if anyone at NHRA has any technical knowledge. |
#54 |
Liked 1,111 Times in 304 Posts
Bryon Worner, I believe that you run a SB Chevy, correct? An engine which probably has a wider selection of available race style intake manifolds than all the other engines that can run in Super Stock combined. In your opinion, do you think that it is "fair" that a SBC can choose from 30 or more intake manifolds, but a less popular engine should be restricted to 5000 RPM "RV" style dual plane intakes, if that is all that is commercially available? Frankly, if a 100 % hand fabricated sheet aluminum intake is legal in S/S, under the "any intake manifold allowed" , I really can not see why one should not be allowed to do whatever modifications are required to make any intake fit any cylinder head, provided it all fits under the hood.
#55 |
I think that sometime soon this rule is going to get clarified.
#56 |
Liked 8 Times in 4 Posts
The new ruling is not in the intake manifold paragraph of the rule book. It is in the cylinder head paragraph. Spacer plates are being used to make up for what is cut off the intake side of the cylinder head. The heads are being cut at a severe angle so the valve cover bolt holes remain intact and runner volumes can meet the spec.
#57 | |
#58 | |
Liked 535 Times in 86 Posts
#59 |
Liked 128 Times in 33 Posts
More changes:
http://nhraracer.com/content/general...696&zoneid=132 |
#60 | |
Liked 72 Times in 27 Posts
