Old 10-28-2019, 10:57 PM   #21
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Default Re: REM and Surface Treatments
Originally Posted by Jim Bailey View Post
The key is to not "shock" the part by cooling it too quickly, and to not warm it back to room temp too quickly. The program we used for a ring and pinion was 8 hour descend, 8 hour soak, 8 hours back to ambient, follow by a 2 hour "normalizing" where the parts are warmed to +200 degrees for an hour, then allowed to cool to room temp all by them self. Good Cryo machines can do all these steps without ever opening the machine once a run begins. There will be little, if any, effect on the parts heat treatment. Additionally, the Timed Steps of the run are based on the total weight of the parts in the machine... If you really want to "see" cyro in action, treat your Drill Bits, Mills, and Lathe Tooling... Now you know the rest of the story. ...
Jim,
Do you treat different types of parts to different process times? Ring & pinion, valves, and valve springs have all been mentioned. I would imagine that some stick shift racers treat transmission gears. Interested in your comments. Trying to learn more about this process.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 10-28-2019, 11:26 PM   #22
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
That's a pretty broad statement Ralph …. Much better stated as cryo done incorrectly can make your part brittle. You could program your machine to slowly lower the part to Cryo temps ( -300 degrees ) say over 48hrs. Once the part has reached the "soak" cycle say -310 degrees, It can stay there as long as you wanna spend money on Nitrogen to keep it there. Which would be a waste of time and money. The key is to not "shock" the part by cooling it too quickly, and to not warm it back to room temp too quickly. The program we used for a ring and pinion was 8 hour descend, 8 hour soak, 8 hours back to ambient, follow by a 2 hour "normalizing" where the parts are warmed to +200 degrees for an hour, then allowed to cool to room temp all by them self. Good Cryo machines can do all these steps without ever opening the machine once a run begins. There will be little, if any, effect on the parts heat treatment. Additionally, the Timed Steps of the run are based on the total weight of the parts in the machine... If you really want to "see" cyro in action, treat your Drill Bits, Mills, and Lathe Tooling... Now you know the rest of the story. ... Hopefully, you're now armed with enough info to ask the correct questions at your Cryo shop of choice. If they're skipping any of these steps, beware of any BS that will follow in their excuses and explanations of how they do it !
Would Cryo work with axles?
D
Old 10-29-2019, 08:06 AM   #23
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs up Re: REM and Surface Treatments
Cryo works with just about any material …. It's just that some materials respond / improve more than others to the process. Do a little research and you'll find that many of your parts are already done by the manufactures. I'd bet that most all after market standard trannys come with cryo'd and rem finished gears an shafts, along with many of the crankshaft companies....Basically your only limit is what size part will fit in the machine.
Jim Bailey is offline   Reply With Quote
