#111 |
Liked 2,353 Times in 466 Posts
I agree with Dave the double points race is why I went there. After the first time trial it was apparent the traction wasn't the best and the tree was real loose. Made adjustments and hooked good for the next two passes. The starting line crew worked hard and stayed after it to give us the best they could. My car just didn't want to make first round. BP
#112 |
Liked 138 Times in 28 Posts
It was the worst starting line and track I have been on this year ok
Sterling Simmons jr 1131 STK |
#113 |
Liked 1,443 Times in 302 Posts
I had never been to Rockingham. I had adjusted shocks and clutch prior to going there for the test session and it worked well. I had my best 60 foot times and ets. My 60 foot times did not vary more than a hundredth. I was stupid and didn’t adjust my clutch pedal for rollout until it was too late. It was different and definitely looser.
Now I have a big tire LT1 combo so it is easier to hook than a 800 hp small tire radial deal, but there are times in the summer where I really have to adjust in the heat to hook and the automatic racers don’t seem to have a problem. I guess some cars are a little more sensitive than others with Radials and lots of power, converter and gear. I am sure they can be adjusted as well. That being said, I watched some cars spin that should never spin. Looked like the starting line crew was working the line, but they seemed to spray a lot maybe too much on the line so it might have made things worse at times. The water box was pretty bad. Sometimes no water and sometimes messy. Now some of that could be avoided if the guys wouldn’t go too fast through the puddle and drag water ten feet past the box. That being said, the track crew should watch for that. All in all, the track location, facility and surface is more than workable. I am sure with some oversight and coaching the starting line can improve. There are ways to adjust race cars as noted. Maybe bias ply tires aren’t so bad after all. I couldn’t run Radials either. LOL
James Schaechter 3163 STK Last edited by james schaechter; 10-25-2019 at 04:38 AM. |
#114 |
Darlington would be a great place to race... Only if they were NHRA sanctioned. I rather go there then rockingham. Just my two cents.
#115 |
Liked 535 Times in 86 Posts
I disagree Sterling. The Virginia national event had by far the worst starting line. But it was pretty bad as the days went on. That’s why I left all the weight in my car and ran SS/JA instead of running GT.
#116 |
Congratulations Bryan, great driving at the Rock.
