Liked 227 Times in 74 Posts
Im building a 1971 Ford Torino 500 hardtop. It has a 302 2v Autolite 2100 carb completely stock engine with a C4 and a 9inch rear. I also have stock Iron cleveland 4v heads and the matching Iron 4v intake and just need a block. Im trying to decide to either run T/SA or U/SA with the 302 2V or G/SA or F/SA with the 351C I just need a block and a Holley 0-3310C or I could just build a footbrake bracket car. Im not really shur what direction I wanna go or what would make the most sense? I also have a Jim Paquet C4 4800 stall converter.
Liked 242 Times in 81 Posts
Isn't that like the Starsky and Hutch car? Put a red stripe on it and make it the reverse paint job. Was the Torino available with the 429? Godd luck in what ever way you decide to go.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#4 | |
Liked 7 Times in 5 Posts
Roland |
Liked 237 Times in 126 Posts
If I'm right, your head numbers need to be
D0OE-B 302/140 D1AE-CB 351C/240 for stock.
Exactly actually this car is pretty light at just around 3,000 ibs and thank you firesale anybody know who can build a badass Autolite 2100 carb?
#7 | |
Liked 5,155 Times in 1,968 Posts
HP too high on the 302.. Should run under, but not a lot , without opening the wallet wide.
Liked 173 Times in 52 Posts
So i looked in the guide. Is the 429 not considered a good combo at 350hp? Lots of compression big bore short stroke .500 lift cam.
There are actually 3 different versions of the 429 4 barrel engine available in a 70 Torino. The base "Thunder jet" has the Autolite 4300 carb and standard heads , the Cobra Jet has a bigger hyd. cam, bigger valves and ports, and a Rochester Quadrajet (REALLY!), and the Super Cobra Jet has a solid lifter cam , the big heads, and a Holley 780. All the 4 barrel 429s had pretty high compression, and NHRA rolled the HP below factory a while back. A number of 71 Mustang Stockers are using the 429 SCJ engine, see no reason why the larger and heavier Torino couldn`t work too. But the 70-71 Torino is a pretty heavy car, I did not look at the Classification Guide, but a factory 429 70 Torino my buddy used to have was well over 4000 pounds with a skinny driver behind the wheel. The 351 Cleveland 4 barrel engine was also available, but he 70 had a smaller cam, and unless things have changed, are not able to use the big Holley carb the 71-72 351 C 4 barrel is allowed to run. With a 302 2 barrel, I doubt you could get the Torino light enough to get near the top of U/SA, let alone T.
