Old 09-03-2019, 08:19 AM   #11
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Oil Level
Originally Posted by Adger Smith View Post
Try it on the dyno..
Cut up a pan and put a sight panel in it.
I tried it with a sight level tube on the outside of the pan on both sides, first..
Scared me how low you could go in a static position.
SS/Div6 that return to the sump by the bypass should cut down on the aeration of the oil coming out the bypass.
That is a huge benefit in lubrication. Air bubbles don't cool or lubricate.
I've done this. My question is does the engine make more power with less oil, or on the verge just enough oil, I I'am down 1 mph with no signs of windage problems with an extra 2 quarts in the system.
Name:	oil sight.jpg
ID:	51539   Click image for larger version
Name:	oil pan testing.jpg
Old 09-03-2019, 01:27 PM   #12
SSGN
SSGN's Avatar
Liked 201 Times in 52 Posts
Lightbulb Re: Oil Level
I didn't think you could run a modified pan or accumulator in stock.. Correct me if I am wrong on this.
Thanks
The more people I meet the more I like my dog
Kevin
Old 09-03-2019, 05:02 PM   #13
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Thanks
You can run an accumulator,and NHRA has a list of accepted pans you can use.. gsa612
Old 09-04-2019, 08:18 AM   #14
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Is that the pan you run in Stock? Do you log oil temperature?
Pedigo Perf is offline   Reply With Quote
Old 09-04-2019, 07:02 PM   #15
Pretty sure that's a Chevy pan, and we're talking about a Buick here. ;-)
Old 09-04-2019, 08:53 PM   #16
gsa612
gsa612's Avatar
That's a Chevy pan on a Chevy engine,with the filter in the back.Buick filter is in the front,and the pan mounting is completely different. gsa612
Old 09-05-2019, 10:12 AM   #17
Mike Jones
Liked 684 Times in 289 Posts
Mike A114
