Old 08-15-2019, 08:58 PM   #11
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: National Event Sportsman Teardown Announcement
Originally Posted by jamie2370 View Post
Copied and pasted from Nhra racer website, posted today
Moving forward, the NHRA Technical Services Department would like to remind all Sportsman Racers (i.e. Pro Mod, Top Alcohol Dragster, Top Alcohol Funny Car, Competition Eliminator, Factory Stock Showdown, Stock Eliminator and Super Stock) to be prepared for teardown when attending an NHRA National Event. All racers should bring any and all necessary tools and/or equipment, as well as any and all necessary parts and components (including but not limited to gaskets) to complete a full teardown and reassembly prior to further competition. Thank you in advance and we look forward to seeing each and every one of you at a future NHRA National Event.
Was anyone torn down at Brainerd today?. gsa612
Old 08-15-2019, 09:54 PM   #12
SSDiv6
Originally Posted by Steve Polhill View Post
Comp is allowed any internal Modifications,as is Top alcohol. If I set a record they pump the engine and check for illegal equipment and done. If NHRA wants to pull a Piston in my DOHC Comp car they are going to have a fight on their hands.
Steve,
There are still many things that can be checked in Comp such as making sure they run the correct size/type of carburetor. Pumping the engine for claimed cubic inches and also, to make sure they run the correct engine bore spacing. The rumor mill says there have been instances of some guys running small block Chevy engines with 4.50" bore spacing in classes were they must run the OEM, 4.40" bore spacing.
Old 08-15-2019, 10:06 PM   #13
G Schenck
Liked 81 Times in 35 Posts
Steve,
At Noble points race they had Bourgeois pull a head to check bore and stroke, bore spacing, injector size, rear tire width and wheel base. At Tulsa they had Rampy, Hildalgo and I believe Pitt and Stanfield pull a head.
Greg
G Schenck is offline   Reply With Quote
Old 08-15-2019, 10:25 PM   #14
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Steve,
It’s happened and people have been tossed (bore spacing)
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
