#1291 |
Liked 242 Times in 81 Posts
So you are mounting the race pak sensor for the trans through the fill hole?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#1292 |
Liked 1,954 Times in 491 Posts
No, I'm going to drill and tap the case under the fill plug to line up with the counter shaft.
Todd Greene |
#1293 |
Tapped holes for all the pipe plugs today and did some more grinding and chamfering on the block.
Todd Greene |
#1294 |
Not much done today, only the lifter bores grooved.
Todd Greene |
#1295 |
Liked 7,682 Times in 1,730 Posts
Why????????????????????????????
#1296 |
Liked 372 Times in 129 Posts
LOL ahhhhhhhh
I can only say we go to great lengths to control oil leaks in the engine, and 16 lifter bores is definitely one of the places were looking to control. Last edited by HP HUNTER; 06-24-2019 at 07:24 PM. |
#1297 |
Because I don't think the cam will live with 400+lb of spring pressure and no help.
Todd Greene |
#1298 |
Liked 544 Times in 213 Posts
I’m glad I was not the first one to say WHY ?
Geez. I built a low buck 350 for my buddy when he first started racing. Cast HyperE pistons, cast crank, stock rods, flat tappet cam with .012” EDM’d lifters Cam had .500+ lift I’m sure and 400lbs open pressure or dang near it. It lived for years and went 10’s in a 2800-2900 lb Camaro running brackets and S/ST and the engine got sold running minus top end ....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 06-24-2019 at 08:57 PM. |
#1299 | |
Todd Greene |
#1300 |
Liked 969 Times in 307 Posts
What size are those grooves? Lifters have edm holes? Didn't you have an oiling problem already?
