#91 |
Liked 11,017 Times in 2,265 Posts
Our wiring guy--Mr. Bob Toy!
#92 |
I have to make a guide to help install cam bearings tomorrow. About the only tooling I could use from the B, RB engines is the engine stand the mikes, and my data recorder ( pencil and paper).
#93 |
Larry, would you mind sharing which block you are using? If you have the part number that would be most appreciated.
Thank you! |
#94 |
It's the one that has unfinished bores and mains, it's not very strong. Part # P5153898
The new ones are from DSR Last edited by Larry Hill; 06-11-2019 at 10:02 AM. Reason: add part # |
#95 |
Today was a first. We installed the cam bearings installed the camshaft, are you ready for this, it turned. No gnashing of teeth,or anything but a smile. It was a very good day.
#96 |
Thank you!
#97 |
All new parts engines need to have a bolt kit. Finding all the correct size, length, grade, and type has been a real treasure hunt. Dowels and O rings can be elusive. You can't afford to buy each bolt from the dealer. A valve cover bolt is $5.00 X 10 bolts per cover X 2 covers = $ 100. Solution for me is going to the local salvage yard and harvesting a lot of used parts. Billy will be so proud of me.
#98 |
Today has been a bad day, I feel like I was a tackling dummy.
#99 | |
Todd Greene |
#100 |
If you need a small piece of shim stock to shim something and you live in the middle of nowhere or all the stores are closed. Open a few can goods and use the tops. I found them to .005'' to .012'' thick. This weekend it was Charlie The Tuna to the rescue, .007'' was perfect
