Liked 136 Times in 49 Posts
I am ready to convert my car from all drums to all disk brakes. Any suggestions for a kit. I would prefer to get a kit that has everything so I know it is all set up to work together. Don't really want to experiment with brakes.
Thanks John Its a 1970 Nova I/SA Last edited by novassdude; 05-15-2019 at 05:11 PM. |
Liked 43 Times in 29 Posts
I had great luck with Master Power Brake
https://www.mpbrakes.com They are friendly and knowledgeable. you may want to consider upgrading your drum brakes
Mark Ruset 2048 STK |
Liked 15 Times in 11 Posts
Strange makes front and rear kits that are light and work very well, Wilwood race brakes are good too. Just two suggestions.
What front Wilwood brakes are people with heavier cars using? The race ones I have found all top out at 2800 pounds.
Thanks John |
Liked 237 Times in 126 Posts
Strange S series front and rear on my 3300 lb. Mustang. Stuck with a power MC and it stages and stops on a proverbial $0.10. Switched over from Wilwood street brakes.
Liked 2,019 Times in 606 Posts
When I converted my car from drums to disc brakes I used Aerospace. The brakes fit perfectly and worked perfectly too. No drag issues at all. Stopping power is way better than the drums ever were. also was about a 60 lb. weight reduction. Every bolt and nut came with the kit. The only thing I had to do was get the appropriate braided stainless lines to connect the calipers to my existing system.
Mike Pearson 2485 SS |
I really like the Aerospace kit as well. Easy to install and as Mike said everything included in the kit and easy to follow instructions as well.
