Old 04-22-2019, 10:05 AM   #1
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default A ? about alternators
Not sure if this is the right forum. In an attempt to shed weight off the front of my 85 Mustang bracket racer. I'm looking to replace my FOMOCO 3G alternator with a smaller compact unit. Trying to follow the mindset of "removing 1lb. from 50 areas versus 50lbs. from one area" rule. I'm pretty sure that people have been using small high output alternators off of foreign cars to achieve the same result. If I'm correct my 3G puts out 95 amps. I would want to stay the same amps at the very least as i am running and electric fuel pump/ fan/ Mezziere water pump. Any advice would be greatly appreciated. Thank you in advance.
Mitch Beri- The Motor City
Old 04-22-2019, 11:09 AM   #2
J&S Racing
Liked 327 Times in 87 Posts
Default Re: A ? about alternators
East Coast ultra mini!!!!!
J&S Racing is online now   Reply With Quote
Old 04-22-2019, 11:15 AM   #3
black88coupe
Will check them out. Thank you sir.
Old 04-22-2019, 05:52 PM   #4
Dragsinger
Liked 99 Times in 60 Posts
also, check with Mark Payne at House of Payne Performance
Larry Woodfin 471W
Old 04-22-2019, 09:16 PM   #5
black88coupe
Thank you. Looking at S10 alternators. They look compact and are 100amps.
Old 04-24-2019, 11:45 AM   #6
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I burned out a mini (Nippon Denso) and replaced it with a TuffStuff 7068k high amp. Set the needle on 13v all day.
Dale Shearon
68 Mustang 6394
