Liked 133 Times in 76 Posts
When you have a class race and you want to cool the motor how do you drain the block if you have a diaper?
Liked 237 Times in 126 Posts
I've seen a bypass installed in the radiator hose that allows you to quick connect an external cooler to add to the system. Something like routing the radiator flow through a Coleman cooler full of ice water.
Commercial solutions Ouch!!! https://timmcamis.com/shop/chilly-wi...ne-cooler.html Less Ouch (not by much) https://www.sonnysracingengines.com/...down-unit.html
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 04-06-2019 at 12:39 AM. |
Liked 10,849 Times in 2,254 Posts
Put hose on end of drain valve.
