I just bought a 2014 super cobra jet trying to figure what class I can fit into
It’s all stock Thank you |
Liked 783 Times in 195 Posts
I have a question about this subject. I found my car in class racer info and it says the weight and index,ok.now I see that car got 20hp added a while ago.so where do you find the weight that the car has to be right now.more hp means more weight correct? car is a 2009 6.1 dp manual
Scott justo. 2009018 lc22r |
Liked 249 Times in 48 Posts
Go to the site Dwight listed click on the wt/hp for the your car and it will give you the three classes and the minimum weight for each.
Pete |
I found the car on the site.its a natural class fx/d min.wgt w/driver 3230.
my question is if I show up at a nhra race,the car with me in it has to be 3230. im just trying to figure this out so I can join in on the fun.
#6 | |
Liked 503 Times in 131 Posts
Better to run it in e 3434 min 10.95 index to start till you learn the lay of the land and how much you need to spend to go fast. You can always pull some weight out Just my 2 cents I've been running a drag pak since 2010. Eric
Eric Merryfield 1883 STK |
#7 | |
Liked 239 Times in 114 Posts
thanks for that eric.i understand now.im waiting for track at Earlville to open so I can get on the scale and make first pass.
