• 9” Mark Williams Aluminum Center Pro
Lighten Gear 5:43, 40 Spline $1,100.00 • Ring & Pinion Set Ford 9”, 5.29 Lighten $140.00 • Ring & Pinion Set Ford 9”, 5:43 Lighten $140.00 • GM 12 Bolt 5.38 $75.00 • Crane Roller Lifter Sets, 7-Sets, 80-150 Runs $100.00 each set • Torque Converters , 7 total $2,000 for all seven 4-7” , 2- with PG Spline -2 Turbo OR 3-8” , 2- with Turbo Spline, 1-PG $350.00 Each All 5800 or more in 600+ HP+ • Engine Cool Tank- 12V Pump $200.00 • 13” Electrical Fan $30.00 • Biondo RPM -2-Shift $50.00 • 2-Biondo 2” Transbrake Button $75.00 each • 2-Bindo 4 ½ “ Transbrake Button $50.00 each • 6 Sets Used Pushrods (different lengths, 7.700-7.925) $ (ask) One New Set, 7931 Comp. 8.280 (16) $60.00 • 16V-12V Battery Charger Moroso Power Charger (No- 74016) $100.00 • Aluminum Light Valve Covers (Tall) LT1 or L-98 $100.00 • Wheels Weld- Magnum Drag 5” (4” back) 15x14 set $450.00 Weld- Aluminum Star, 4 ½ “ (4” back) 15x12 set $400.00 Weld-Pro Star, 4 ½ “ (1 ¾ “ back) 15x12 set $300.00 • 350 Olds Parts New Autolite Plugs AR3910, 6 sets $100.00 350 Holley Manifold $150.00 • Scott McClay M-200 Transmission 2.57 Low With After -Market Bellhousing & Brake $3,500.00 • Gear Sets- 2- 2.41 and 1- 2.24 $150.00 each • Misc. Clutch Packs, Used Aluminum Drum $ (ask) • Sheet Metal Manifold, Small Block Chevy L-98 or LT-1 $1,200.00 Other Misc. !!!!!! ASK!!!! Motorhome for Sale 2003 Dutch Star by Newmar 40 ft with 3 slides, 350 Cummins Diesel, Sleeps 4, Always kept in Heated Building, One Owner, 117,500 miles. VERY CLEAN!!!! $69,000.00 Van Buren, OH Jerry, 419-348-3336 |
Liked 976 Times in 311 Posts
Pm sent
Liked 33 Times in 17 Posts
Jerry,
You have a PM. -Todd |
Liked 36 Times in 15 Posts
Pm sent
Jim Lodi jr |
Pm sent
Liked 520 Times in 132 Posts
PM sent
