Old 03-10-2019, 07:16 PM   #1
jimmyparker
Liked 309 Times in 88 Posts
Default V-10 Ford 2 valve ECU mods?
Anyone had any luck using any of the re-programmers that advertise HP and torque gains for V-10 2 valve powered RV's?
jimmyparker is offline   Reply With Quote
Old 03-11-2019, 02:32 PM   #2
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
Default Re: V-10 Ford 2 valve ECU mods?
I am getting ready to purchase something......but I have had several first hand accounts from fellow racers that are happy with the 5 Star rv tuner
F Federico
NHRA J/SA
dragracer502 is offline   Reply With Quote
Old 03-12-2019, 12:46 AM   #3
Rory McNeil
I have not done any modifications on my 99 V10 2 valve yet, but I have also heard good things about 5 Star. However, as I understand it, most of their improvements revolve around changes made to the automatic transmissions reprogramming. Since my F350 is a 5 speed manual, that is not a consideration . My V10s exhaust manifolds look pretty restrictive, as does the exhaust Y pipe, but after hearing about the problems with the studs snapping off in the cylinder heads, not sure I want to try unbolting the exhaust manifolds to install headers. Supposedly the 2000 & newer 2 valve V10 heads are better than the earlier castings, but looks like a major job to change, and I have heard that the intake manifolds are different as well. No idea if the chamber volumes and shapes are compatible between early & late 2V engines.
NHRA 6390 STK
M/S 85 Mustang
