Liked 225 Times in 30 Posts
8 3/4 Mopar ring & pinion , 742 case 5.33 ratio,used, good condition
10 spline, $150.00 8 3/4 Lightweight steel spool with bearings, used, good condition for 30 spline axles, $150.00 8 3/4 pinion yoke, large u joint [ 7290] 10 spline, used $45.00 8 3/4 pinion yoke, small u joint [7260] 10 spline, used, $35.00 8 3/4 pinion yoke, large u joint [7290] 29 spline, used $ 45.00 1pr Centerline Convo-Pro 15x4 frt wheels, good condition, 4 1/2 bolt circle $250.00 1pr Centerline Convo-Pro 15x10, 5" back space, 4 1/2 bolt circle no screw holes, good condition, $ 350.00 All 4 wheels $500.00 New M/T 29.5x10.5x15R Pro Bracket Radial Slicks, Never Mounted, $ 475.00pr. Can deliver to Vegas or Pomona. 760-630-9094 |
Liked 5 Times in 2 Posts
Just wanted to clarify, are the gears 5.33 or 5.13?
Thanks
5705 F/S 5706 D/SA |
Gear ratio is 5.33,32 teeth on ring, 6 on pinion , very rare.
