Old 09-17-2018, 06:39 PM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: plastic printing
Originally Posted by Myron Piatek View Post
I'll ask/check around. Don't know if it's accurate, but I've heard it referred to as "phenolic".
There is a source for small primary bowls for under $150, which I don't know if they are still being manufactured or there is just a large overstock. But no source for big primary bowls that I'm aware of.
i just joined a 3d printing forum and asked if there is any plastic that can stand being in contact with gasoline. i am going to take apasrt a junk tq i have and see what it looks like and what screw holes that would have to created. do you think having brass inserts for the screws to be needed?
Old 09-17-2018, 09:20 PM   #12
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: plastic printing
From what I've seen, the only brass inserts are for the primary jets. Then there are those 2 "caps" that are epoxied under the main jets. All of the cover screws thread into the aluminum base. The fuel bowl center section simply provides "pass through" holes.
I'm still learning and coincidentally, took apart my first 2 good TQ's, changed the jetting and reassembled them this past weekend. Still gotta try them out.
LOCOMOTION Racing
Old 09-18-2018, 12:41 AM   #13
Chad Fergen
Liked 24 Times in 12 Posts
can you tell me what printers you are using?
Thanks
All are Stratasys. The largest we can do is a 18 inch part.
Chad Fergen is offline   Reply With Quote
Old 09-18-2018, 12:43 AM   #14
Chad Fergen
Thanks
If you are looking for an inexpensive printer to get started, let me know. "i got a guy" txt605-690-1240
