Liked 8,238 Times in 1,540 Posts
If you are traveling south on I 65 heading to Bowling Green a good place to stop for diesel and gasoline is in Kentucky at exit 105. Most diesel in Ky. Is 2.99 a gallon and gas at exit 105 is 2.49...Diesel fuel is quite a bit MORE expensive in Indiana. In the Bowling Green area there is FREE dumping at Campers World which is located off exit 22, a few miles from exit 28 which takes you to the track. On the way to Indy you can also dump at Flying J in Whiteland ,Indiana which I believe is exit 95.
They have raised the price of diesel at exit 105, although gas is still 2.49 a gallon..there are numerous truck stops between BG and exit 105 with diesel below 3 bucks a gallon. Just remember that diesel in Indiana is quite a bit more so it’s a good idea to fill up in Ky.
