Liked 80 Times in 44 Posts
I need a k-frame for a 383 engine. 210-887-3331 Thanks
Liked 332 Times in 180 Posts
Kirk-- I "believe" all V-8 K members are the same EXCEPT the HEMI--If its a 6 cylinder k member then i " believe" they are different- you need to just raise the adjustment on the torsion bars for the additional weight--- Check other Mopar guys to be sure
Liked 346 Times in 126 Posts
have you put a wtb on http://www.forebodiesonly.com/
Liked 138 Times in 51 Posts
You can also search on:
http://www.cuda-challenger.com/ http://www.moparts.com/ FED 387 is correct. E-body standard V-8 K-members will accept a small or big block with only the correct engine side motor mount brackets needed. /6 k-member could be used with adapter mounts. Not sure on the details of a Hemi version. But they are too expensive anyway. Just make sure you're getting an E-body K-member and not one from a B-body.
LOCOMOTION Racing Last edited by Myron Piatek; 08-08-2018 at 12:20 PM. |
Liked 239 Times in 114 Posts
Are the B body K frames the same as E body K frames ?
Liked 53 Times in 38 Posts
Liked 140 Times in 46 Posts
E-body and 71-72 B-body k-members interchange.
70 B-body is different. The steering box mounts at more of an angle on 66-70 B-bodies.
Jon Sarrett Stock 3779 |
I knew there were differences, but didn't know the details. Here is a thread from moparts.com that discusses the topic.
I thought there was a mounting point difference. But it sounds like there might be some geometry issues and perhaps a steering shaft angle change could interfere with headers. http://board.moparts.org/ubbthreads/...-e-b-body.html
LOCOMOTION Racing |
Thanks for the info. Iam over 60 and this is my first Mopar. I have always had Fords.
After reading about steering box angle, I checked my 73 E-body k frame to my 67 B-body k frame, both have the same angle. Around 24 degrees from level.?
