Old 08-07-2018, 06:24 PM   #1
Kirk Morgan
Liked 81 Times in 45 Posts
Default 70 Dodge Challenger
I need a k-frame for a 383 engine. 210-887-3331 Thanks
Kirk Morgan is offline   Reply With Quote
Old 08-07-2018, 06:42 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: 70 Dodge Challenger
Kirk-- I "believe" all V-8 K members are the same EXCEPT the HEMI--If its a 6 cylinder k member then i " believe" they are different- you need to just raise the adjustment on the torsion bars for the additional weight--- Check other Mopar guys to be sure
Old 08-07-2018, 07:50 PM   #3
David Lee
Liked 346 Times in 126 Posts
have you put a wtb on http://www.forebodiesonly.com/
Old 08-08-2018, 07:10 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 70 Dodge Challenger
You can also search on:
http://www.cuda-challenger.com/
http://www.moparts.com/
FED 387 is correct. E-body standard V-8 K-members will accept a small or big block with only the correct engine side motor mount brackets needed.
/6 k-member could be used with adapter mounts. Not sure on the details of a Hemi version. But they are too expensive anyway.
Just make sure you're getting an E-body K-member and not one from a B-body.
LOCOMOTION Racing
Old 08-08-2018, 11:00 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Are the B body K frames the same as E body K frames ?
Old 08-08-2018, 01:20 PM   #6
Coleydog
Liked 53 Times in 38 Posts
Depends on what year, B&E 70 up same, 66-69 have different sway bar mount but will work if not using bar.
Old 08-08-2018, 02:13 PM   #7
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
E-body and 71-72 B-body k-members interchange.
70 B-body is different.
The steering box mounts at more of an angle on 66-70 B-bodies.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 08-08-2018, 02:42 PM   #8
Myron Piatek
I knew there were differences, but didn't know the details. Here is a thread from moparts.com that discusses the topic.
I thought there was a mounting point difference. But it sounds like there might be some geometry issues and perhaps a steering shaft angle change could interfere with headers.
http://board.moparts.org/ubbthreads/...-e-b-body.html
LOCOMOTION Racing
Old 08-08-2018, 05:55 PM   #9
Kirk Morgan
Thanks for the info. Iam over 60 and this is my first Mopar. I have always had Fords.
Old 08-13-2018, 12:40 PM   #10
Coleydog
After reading about steering box angle, I checked my 73 E-body k frame to my 67 B-body k frame, both have the same angle. Around 24 degrees from level.?
