#161 | |
Liked 117 Times in 50 Posts
If you're able to run it, it would be a natural J/S car at 12.78 pounds per factored horsepower. You could add or subtract weight to run one class up or down (K/S or I/S). If the one you have is a Performance Package car, they have larger/heavier front brakes than the non Performance Package car. Have you driven it? Last edited by 6130; 06-26-2018 at 10:51 PM. |
#162 |
Liked 130 Times in 42 Posts
I want to see Ecoboost Mustangs heads-up racing Ecotec Camaros. Stick only and we could call it Jr Factory Stock. It would sound like a swarm of mad bumblebees
#163 | |
Liked 128 Times in 50 Posts
Bobby Lundholm 3516 G/SA |
#164 |
I don't think the GT350 (or it's flat-plane engine) is listed in the NHRA Stock Classification Guides, and it's only available as a stick-shift.
#165 |
I didn't think it was either. I think the ecoboost Mustang would be a fun ride. Stickered at $35,000 isn't that bad either.
#166 |
#167 |
Very true. I think this is the top of the line package. Orange Fury is the color.
#168 | |
The "Premium" Ecoboost Mustang starts at $30,860. The Orange Fury paint (which I like) is a $495 option. And the "Performance Package", which adds 19" wheels, stiffer suspension, 3.55 Torsen diff, bigger brakes, and a few other odds and ends, is a $2,495 option. This option would make it more fun as a street car, but the extra weight would not be helpful for a drag car. I'd pass on the "Performance Package" and put that $2,495 into things that make it go faster. |
#169 | |
https://performanceparts.ford.com/part/M-4209-88409A https://performanceparts.ford.com/part/M-4130-MA
#170 | |
And I'd run the numbers before purchasing the 4.09 ring & pinion- the power peak on the Ecoboost engine is only at 5,500 rpm. First gear is so deep, that you'd have a pretty steep launch ratio even with the stock gearing. And turbo engines tend to be more tolerant of taller gearing anyway. |
