Liked 684 Times in 289 Posts
I am completing purchase of an empty SBC block, in a couple of weeks.
I need to get it from Florida to Connecticut. Its a possibility, I can have it at the Memphis National (6/15-17). I need help the rest of the way, in getting it to Ct. If you are able, or know someone who is, I would appreciate it. Thank you, Mike |
Liked 56 Times in 27 Posts
Mike,
Have the person your buying the block from in Fla. find a Trucking Company that can deliver it to a depot close by in Conn...I use to send my Tranny's to TCI in Ala. to be rebuilt, in a heavy duty plastic tub ??? * Check it out , you may find it cheaper ?? Good Luck...
Dave Ribeiro 1033 STK |
What Dave said, I have shipped 2 transmissions to Turbo Action on the same pallet for like $125. If you can't find another way truck freight is a good option if you do some research.
Thanks Dave and Jim
Ill check into it.. Mike |
Liked 584 Times in 94 Posts
Mike, I've had really good luck shipping heavy parts from Florida to Pa and Indiana with R&L. You can really save a lot of money if you can find a business to ship it to and from. I have a buddy with a mower shop that he lets me ship from. The cost savings is huge.
Liked 1,975 Times in 597 Posts
I have also used R&L in the past to ship engines and transmissions. If you can get dock to dock at their terminal it is pretty reasonable. Also someone posted that Fastenal also does shipping. You might check in to that if they are local to your area.
Mike Pearson 2485 SS |
Liked 335 Times in 182 Posts
Look into Greyhound if its not to heavy they will do it reasonably---u might have to drive a little on both ends to get the job done tho---that is drop off for shipment and pick up at the other end
Thanks Jim ,Mike, FED
I`ve got work to do I will post relevant info Thanks again, mike |
Liked 19 Times in 6 Posts
I've used Old Dominion a lot on rear ends and engines. I can usually ship Diff's for 100-125 bucks almost anywhere and engines a bit more. I usually do terminal to terminal. Seems FedEx and UPS are always the highest.
Have the guy build a small simple crate for it, make sure stuff is clean or tell them it's new. If they move it and a gallon of antifreeze or oil or something comes out they'll do all the hazmat crap and price will skyrocket. |
#10 | |
just an empty block, no fluids Mike |
