Old 05-28-2018, 12:06 PM   #1
Marty Buth
Liked 232 Times in 39 Posts
Default A/F readout delay
On the racepak, how much delay from the RPM readout is the Air Fuel readout?
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 05-29-2018, 08:22 PM   #2
Bob Shaw
Liked 323 Times in 63 Posts
Default Re: A/F readout delay
Marty,
On my Holley system it seems to be .4 second.
Bob Shaw V/SA 515
Bob Shaw is online now   Reply With Quote
Old 05-29-2018, 08:28 PM   #3
Marty Buth
Originally Posted by Bob Shaw View Post
Marty,
Thanks Bob! I was expecting something like that How did you determine that amount of delay?
Marty Buth 3657 STK
Old 05-29-2018, 08:49 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
About .2 of a second on the racepak. I look at engine rpm and my shift point vs biggest fluctuation of O2.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 05-30-2018, 09:00 AM   #5
Bob Shaw
My delay is .2 second also. Each step on the graph is .5, not 1.0. I figured wrong.
Bob Shaw V/SA 515
Old 05-30-2018, 09:53 AM   #6
Marty Buth
Thanks Bob Gullett and Bob Shaw! Good information!
Marty Buth 3657 STK
Old 05-31-2018, 10:28 AM   #7
Ed Wright
Ed Wright's Avatar
Marty, if your car is EFI, make a big change at like 6000 RPM, then see what RPM it shows up on your logger. I mostly look at high gear, since the A/F vs RPM error is going to be greater in lower gears due to the RPM increasing so much faster. And, I assume, if you leave off a 2 step, that your launch A/F looks much leaner due to the misfires caused by the 2step. Misfires put more oxygen in the exhaust, and our Wide Band O2 sensors calculate the air/fuel ratio by oxygen content.
I hope if you already knew all this, I didn't offend you. Maybe somebody did not know. Not trying to be a know-it-all.
Ed Wright 4156 SS/JA
Old 05-31-2018, 02:17 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Just looked at my first run here at RT66 , my RacePak O2 is .021 behind RPM
Old 06-01-2018, 06:40 AM   #9
Marty Buth
All good Ed, definitely not offended. I did know about the 2 step. I hadn't thought about altering fuel counts at a specific RPM to track the delay. That is a good idea. Thanks Ed!
Marty Buth 3657 STK
Old 06-01-2018, 06:43 AM   #10
Marty Buth
Thanks Tom! Quite interesting what you are seeing. Bob Shaw and Bob Gullett are seeing .2 seconds and you are seeing ,02 seconds. Do you have any logic about why you are seeing so much less delay?
Marty Buth 3657 STK
