Old 05-24-2018, 04:38 PM   #31
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Car will not start.
Just wondering if this combination ever ran . Is this a completely new built engine / wiring / controller ? My L99 with a Big Stuff controller ran flawlessly , I do remember that the wiring on the pickup needed to be changed to work . These modifications are spelled out on the Big Stuff website . Good luck !
Old 05-24-2018, 06:12 PM   #32
ss3011
ss3011's Avatar
Looked this information up on the Big Stuff website
The wire colors are different from MSD to Big Stuff for the Crank Trigger Pickup Sensor
The MSD purple wire should be hooked to the Big Stuff Black wire
The MSD Green wire should be hooked to the Big Stuff Red wire
Also there is a ground wire from the Big Stuff Harness with a loop terminal , it needs to be attached directly to the engine block . There should be a very good ground wire going from the battery to the block .
Special notice , Damage could occur to the controller if there is battery voltage to the harness, and the connectors are removed from the controller . TURN OFF the master disconnect switch before the connectors are removed or connected to the Big Stuff Controller .
If you can communicate with the controller with your laptop , you can set up a "dash board" that can let you add a tach signal . If you have no signal , then it will never start .
Good Luck !
Old 05-25-2018, 08:04 AM   #33
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by buzzinhalfdozen View Post
After reading back through the posts I'm going to say you're running an MSD ignition box, hooked to the big stuff controller for the EFI side of things is this correct? And if so and you have no spark...look at the MSD part only for now, if the MSD has no spark then you probably aren't producing a tach signal for the big stuff system to work off of.
Been awhile, I recall being able to trigger the MSD without the engine running to check for spark. Can you do that with yours?
Different subject, I also learned in my after high school job not to spin a magneto while carrying it with your hand on top...
Old 05-25-2018, 08:35 AM   #34
buzzinhalfdozen
Liked 11 Times in 8 Posts
If he is set up in the manner I suggested, yes he can trigger the MSD with either an MSD tester or even a paper clip. That's where I was heading but not sure yet exactly what he has.
Joe Buchanan SS/BX 3117
Old 05-25-2018, 08:40 AM   #35
Nmbr1GMfan
I also learned this lesson the hard way!
Todd Greene
Old 05-25-2018, 12:23 PM   #36
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Never handled a magneto, but the first time I tried to move the timing on a running racecar, I just grabbed the distributor cap with my palm across the top of all the wires.
S/ST 51
S/C 53
Old 05-28-2018, 09:44 AM   #37
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
What did you find, Ron/Jason?
Old 05-28-2018, 03:25 PM   #38
TinSoldier 3215
Liked 6 Times in 5 Posts
Kevin. It was a burn wire behind the ignition box. Thanks
TinSoldier 3215 is offline   Reply With Quote
