Old 03-29-2018, 03:46 PM   #21
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
Default Re: '78-'87 El Camino V8 Stocker?
Originally Posted by Paul Wong View Post
Sounds like it is coming to Vegas first!
Like fine wine, some things just take time....
Old 03-31-2018, 12:28 AM   #22
Bruce Fulper
Liked 54 Times in 33 Posts
Originally Posted by GTX JOHN View Post
Check For Sale:
The Late Vic Hobbs Turnkey El Camino Stock Eliminator
$4000.00 OBO
Great way to racing on a budget!
He was a very smart guy and I miss him!
It's in my driveway now. :-)
Bruce Fulper is offline   Reply With Quote
Old 03-31-2018, 05:24 AM   #23
David Lee
Liked 346 Times in 126 Posts
what is the engine combo and how far under does it run?
Old 03-31-2018, 11:10 PM   #24
Bruce Fulper
Will tell you when we get a- - NEEDED~ MSD 6520 box Good used is ok.
Old 04-04-2018, 02:47 PM   #25
Jackie McCracken
Guest
Posts: n/a
Cool Re: '78-'87 El Camino V8 Stocker?
78-83 Malibu's all have different nose/grill AND taillights, make sure they match or a savvy tech guy will ding you. The elco's have different nose/grill for each year until the later ones but the rear bumper and taillights are all the same which also applies to the wagons, all the same. You cannot use after market nose, it must be the original pieces including any spoilers. The 305 4bbl combo is tuff, there a lot of them running (Camaro/Firebird) and the fast ones are really fast. The 79 Malibu 305 carry's 5 HP more than the others, thanks to Billy Lynn ;-)
Jackie McCracken
Old 04-04-2018, 03:18 PM   #26
6130
Liked 117 Times in 50 Posts
Jackie McCracken
So is the '78-'79 350 4-barrel combo not as tough? Would that be a better choice?
Old 04-05-2018, 12:20 AM   #27
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Currently running I/SA ...with a junk engine and a less than optimal track surface it still managed a 1.50 60' that evening.
Rich Taylor
I/SA - 321
Old 04-05-2018, 12:47 AM   #28
Bruce Fulper
Will tell you when we get a- - NEEDED~ Digital 6AL box. Good used is ok.
PREVIOUS info wrong. We need a 6520 MSD box only - thanks
Old 04-05-2018, 12:51 AM   #29
Bruce Fulper
Need 26 x 9 slicks too
Old 04-05-2018, 07:44 AM   #30
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
79 305 4-bbl is good at 235. There are a couple of Arkansas boys that run fast with that combination in hardtop bodies carrying 243hp. The 80-83 small cam 305 engines are also good at 230, and the 84 is at 229. The 83-87 big cam 305s will take more work and $$. The 78-79 350 is good if you will run it as a manual trans; probably better in a SW.
