Old 03-02-2018, 11:27 PM   #1
ACrenshaw82
Default Camaro IHRA Crate Motor Stocker
For Sale: Camaro IHRA Motor Stocker 17,500
Listed on Racingjunk.com, link shown below:
https://www.racingjunk.com/Other/183...r-Stocker.html
'86 car Built by PK Race Cars in 2006
Garage kept, no motor or runs on car since rebuild
Full 10 point roll cage & frame tied
Cross member bar & driveshaft loop
12 Bolt Chevrolet rear end with Olds housing ends & torque arm
Strange Pro 33 spline axles, spool, yoke, disc brakes & adjustable rear shocks
Richmond Pro 5.13 gears
Jegs 12 bolt rear end cover & adjustable panhard bar
Rear 10" Weld Drag Lite Wheels with Hoosier 30 x 10.5R x 15 Drag Radials
Front 4" Weld Drag Lite Wheels with Mickey Thompson 29.0 x 4 x 15
Pro Stock switch panel with starter, ignition, fuel, cooling & lamps all professionally wired
Fuel cell, Weight box, tie downs & Flaming River kill switch
Holley HP150 Fuel pump, Mega Fuel Regulator, #8 braided line, Fuel check bleeder
16 volt battery, Charger, Catch can, Firewall feed-thru
MSD 7AL2 ignition, Coil & 3 step RPM module
Auto Meter gauges, Tach, Temp, Oil, Fuel & Voltmeter
Hurst Pistol-Grip Quarter Stick PG with line-lock & Stage Control Solenoid
Aluminum radiator with 16" electric Fan
Motor Mount Plate & Mid Plate & Drive Shaft
Moroso Coil Spring Front Race Springs & 5/8" Moly Rod Ends
Barry Grant Quick Disconnect Removable Steering Wheel
Powder Coated Front "K" Member - Vega steering box
Bare Body Painted on a Rotisserie
Everything New
This car will come with Bill of Sale.
Call or text with serious inquiries only (828) 337-7465
ACrenshaw82 is offline   Reply With Quote
