Old 02-22-2018, 02:14 PM   #1
DRAKE VISCOME
Liked 92 Times in 36 Posts
Default SOLD!!!1988 Mustang GT Stock Eliminator L/M/N
L/M/N Stock Automatic Runs EZ .65 to .70 under the index with room to go faster
302, 215 HP
Currently set up for M/SA, N/SA
3180 lbs with driver (has 140 lbs or so removable weight, our “driver” son Greg @ 205lbs)
Has 50 runs on new engine, all 1/8 mile
Aerospace brakes, front & rear
6-point roll bar
Bogart wheels all around
QA1 shocks and struts
Good Hoosier (lightweight radials, rear) all around
Autometer tach and gauges
Hurst Line-Loc
New Odyssey battery
Fresh in-date 5 point safety harness cam lok
Engine by Danbury Competition and Danbury Chassis Dyno (Jeff Roell, 2015 NHRA Indy Nationals Super Stock winner)
Dart block
Crankshaft offset ground .015
JE Pistons w/millimeter ring packages
Comp Cams blueprinted cam and Sherman lifters
Heads: FIZZ Canadian Castings
Stainless Steel Valves
Beehive valve springs
Roller rocker arms
Canton oil pan
Electric water pump
SFI damper
Aluminum radiator
Calico coated Hedman Step headers w/merge collectors
MSD billet distributor, New Digital 6 box with 2-step, wires
Have laptop and program for it
Transmission:
C-4 (Joel on Joy, Michigan)
2.92 low gear set
Deep pan
Trans cooler
SFI flexplate
Turbo action shifter
Aluminum driveshaft
Moser Axles, spool, C-Clip eliminators
Cosmetics:
Paint: 9 out of 10, original color
Lettering: all decal, ez removable
Car has competed @ IHRA, NHRA and Carolina Class Racer Association events often over last few years
EZ to drive – footbrake or 2-step at 3000, Shift twice @ 5900
Asking $15,000.
EXTRA SPARE EQUIPMENT
1) Kuntz & Company longblock, complete oil pan to intake manifold with coated headers. Includes SFI damper and flexplate.
Just over 100 1/8 mile runs, 15 1/4 mile runs.
Have new set PAC 10 Beehive valve springs & retainers, MSD billet distributor, wires, MSD box, new set rocker arms, gaskets, oil, filter, spark plugs.
Have spec sheet on motor from Kuntz
New from Kuntz $15K now asking $5,000 Sale price with Car Purchase $3,500
2) OEM std. bore Ford block, used
OEM Std. crankshaft, used
New set Venolia pistons and pins
New Comp Cams NHRA legal roller cam & Sherman lifters (Stock eliminator)
New ARP head bolt set
Race Ready (fresh, never installed).
NHRA legal prepared set of cylinder heads, stainless valves, etc. all assembled
**Enough here from another long block, just short of machine work, all new
$2,100
3) Assembled Roller Motor (Stock Street) $500
GT Car
10 gallons Fresh C11 VP/VP Jugs
Oil 5-20W Royal Purple
Oil Filters
Spark Plugs
Gaskets
Drake Viscome
704-528-3594
vrehotford@bellsouth.net
DRAKE VISCOME is offline   Reply With Quote
Old 02-23-2018, 09:50 PM   #2
quickford1
Liked 20 Times in 12 Posts
Default Re: 1988 Mustang GT Stock Eliminator L/M/N
Drake
Give me a call on this when you get a chance.
Rich
quickford1 is offline   Reply With Quote
Old 03-19-2018, 03:45 PM   #3
DRAKE VISCOME
sadly a lil' bit for sure...car-spare Kuntz & Co. motor package is SOLD...
