Liked 13 Times in 7 Posts
This is a question for my son's car and not for my stocker. Can anyone advise me on how guys are using the 16 volt battery systems? Does he need a special starter or ignition system? He runs two batteries so he could separate the gauges, etc. if necessary.
Richard Grant 4988 STK |
I changed nothing. My starter spins faster, coil puts out a hotther spark, lights are brighter, but bulbs don't last real well.
Ed Wright 4156 SS/JA |
Liked 858 Times in 234 Posts
Most newer race components have been designed to be run at 16 volts .
The one exception might be electric radiator fans . ......Most are designed primarily for street use . I've seen a few cars that have had fan motor failures . ...a dropping resister or module takes care of the problem .
Liked 1,019 Times in 367 Posts
Be careful charging it. 16 volt chargers put out almost 20 volts ... That WILL burn things up if you leave your kill switch on. We burnt up a MSD box and when repaired I called and ask why ? Technician said "The 18 volt threshold had been reached"......
Jeff Niceswanger 3740 SS |
Thanks guys. I was hoping that it would be an easy change. Can you recommend where to purchase the battery and charger also the best brands.
Richard Grant 4988 STK Last edited by Richard Grant; 02-12-2018 at 01:14 AM. |
Liked 309 Times in 173 Posts
#7 | |
Anybody else having to buy new 16 volt batteries every season?
Ed: I have only used the Turbo Start brand of 16 v batts. I went 6 years or better with the big batts., changed to the lite weights after cause I felt guilty. The Moroso charger, maybe, was the key, don't know. I will be buying new Turbo Starts for my next racecar soon.
#9 | |
Maybe these will go another year. This DSR charger supposedly goes into a "maintainer" mode. Hope it does.
Liked 799 Times in 336 Posts
One thing to consider about a 16 volt setup is availability. You need a backup plan.
My son manages an Interstate Battery dealership and they can get, but do not stock 16 volt batteries. It is not usual for him to get a desperate call from a racer whose 16 volt battery has failed, they need one to go to the races and cannot find one locally. Bill. |
