Old 12-22-2017, 10:30 AM   #21
M Brand 505B
Liked 31 Times in 10 Posts
Default Re: Aftermarket/Replacement Cylinder Head Rule Change
One of the listed heads is close in CC to the stock specs. This rule is good for guys in the cylinder head business. Now we need a head approved for the Pontiac.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 12-22-2017, 10:47 AM   #22
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
NHRA Approved Aluminum Cylinder Heads
http://www.edelbrock.com/automotive/...approved.shtml
Dan Fahey is online now   Reply With Quote
Old 12-22-2017, 11:02 AM   #23
PJ305
Liked 5 Times in 4 Posts
I have done research on SBC replacement heads and Dart should be the only one approved for Stock. If NHRA is looking here you go.
"DART" WISSOTA #30424361 or #10024361 bare casting plain and simple.I don't believe replacement heads are needed and why would you allow so many with totally out of whack specs. This head is the only one close to Stock, it is cast iron and is very close to your aftermarket specs.If you ever do teardowns you can police one head easier than 8 different ones! Yeah and by the way why isn't it on the list?
PJ305 is offline   Reply With Quote
Old 12-22-2017, 11:47 AM   #24
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
What a can of worms they've opened now....
The Edelbrocks, aside from the fact that they're aluminum, are made for 2.02/1.60 valves and 1.46" springs. So many more grey areas have just been created, and for what?? "But I can't find any old castings!" BS!! I'll buy that line for other brands, but for small-block Chevys?? Get off the couch.
Well, now there's another 5G just to keep up. Thanks.
Paul Merolla is offline   Reply With Quote
Old 12-22-2017, 11:58 AM   #25
Liked 1,928 Times in 434 Posts
Dart or Engine Quest cast iron replacement style heads would have been the correct choice.
However, I'm guessing that neither of them went to the trouble or expense to submit anything.
Anyone who has been through the NHRA approval wringer for anything will understand, especially if they've had parts rejected for subjective illogical reasons.
Aluminum heads for Super Stock make sense, considering the alterations allowed, and the easier repair of aluminum. For Stock, not so much, they just allow cheaper and easier cheating.
Old 12-22-2017, 11:59 AM   #26
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I think that we are missing the point on these replacement heads...
Runner volume is just one way to compare castings...
With the new replacement castings I would like to know what the flow numbers are from each head..
Just because the volumes are the same it has nothing to do with air flow or the horsepower that they are capable of making..
It looks like another can of worms just got opened for Stock...
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 12-22-2017, 12:09 PM   #27
SS734
Liked 4 Times in 3 Posts
If the HP number is low enough, it doesn't matter what head is on what engine.....Take a look at Nitro Joes stats and see who's at the top of the heap in all classes!!!
Still no answer as to how they are combining and reducing to combos.
Anyone care to put their 2 cents in???
SS734 is offline   Reply With Quote
Old 12-22-2017, 12:27 PM   #28
Bobby Lundholm
Liked 128 Times in 50 Posts
Since the new heads come with 2.02 valves to you have to make them comply with the 1.94 valves or run them as they came?
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 12-22-2017, 12:30 PM   #29
Crew Chief
Liked 10 Times in 6 Posts
I can remember a time when a friend submitted a replacement head to NHRA. He was told to bring the new head to a national event along with an OEM head for comparison . The head was looked at by techmen who knew what they were doing. They rejected the head because the intake runner and combustion chamber had been changed in the new casting.
One wonders if the same procedure is used today when a new head gets accepted. By the way, who is accepting all this stuff anyway?
Crew Chief is offline   Reply With Quote
Old 12-22-2017, 12:32 PM   #30
M Brand 505B
The Aftermarket head has to retain the same specs as the head it's replacing.
Michael Brand II
505B - F/SA
