Liked 672 Times in 202 Posts
Casting Date E316 = 5/31/1966 both heads same date
Casting # 3872702 98.4 CC Known as the Bath Tub port heads. These are the largest oval port closed chamber heads only offered in 1966. GM offered these on 396 (325 & 350) and also on Corvette 427 390 horse Heads are complete assembled everything is there including pushrods. They need to be freshened up. $600.00 OBO buyer pays for the ride, if around houston area will deliver for free. Also have the water pump pulley, crank pulley (3 groove), manifolds excellent shape no cracks, oil pan, etc.. SBC parts: Moroso 8 qt pan it has been blasted and painted orange excellent condition $100 Mini starter used excellent condition $100 Complete set of new Child & Alberts main bearings that have been polydyn coated, standard $65 OBO other parts single wire hi amp alternator $75 Comp CamsFast Engineering 4150 1" spacer with rubber to eliminate vibration new in the box $60 OBO Crower 6 finger 3 disc full floater clutch (4 passes old) 168 tooth ring gear, 10 spline input shaft Clutch needs to be freshened up and SFI recertified. Have photos and extra slider discs, clutch packs, for addtional $$$ price $1150 OBO have photos. Hays 5 finger 3 disc full floater clutch 168 tooth ring gear setup for 10 spline input shaft. This clutch needs to be rebuilt and SFI recertified $750 OBO Will make a package deal for both clutches and all spare parts enough to rebuild both clutches 358 C.I. SBC complete carb to pan flywheel to water pump, headers and Bullet racing muffs included, also includes mini starter. 830 Holley double pumper, Dart Intake alot of work done on intake, Dart 215 heads ported bowl work etc.. work done by G&G Houston Tx, SRP Pistons compression is 13.8.1, Manley HD Rods, ARP bolts on all internals, Lunati crank standard (no eagle and scat junk in this motor) stainless ferrera valves comp roller rockers and stud girdle. G&G did the machine work, assembly and dyno. Comp cams 4/7 swap 636/636 252@50 108 lobe center. Motor has gone 9.70 139 in 2520# door car. Motor needs to be freshened up. Wiend electric water pump. Great bracket or 10.90 motor $6500 OBO Powerglide HD case, 1.96 first gear, th400 input shaft, TCI transbrake, red clutch packs, HD pump, excellent condition includes 9" 5500 stall converter, Hurst ratchet shifter with cable and linkage, deep aluminum pan. $1800 OBO. This setup was behind 358. Building BBC & th400 so everything is for sale. 832-727-0326 Last edited by nickh; 12-21-2017 at 09:20 PM. |
updated list and prices
