Old 11-22-2017, 11:12 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Testing Line Pressure TH-350
Where is the port to test line pressure on a TH-350? With my car in low gear it will move forward 15 ft., then when I stop it won't move again. The engine just revs but the car doesn't move. Went through the shifter adjustment and the fluid doesn't smell or look burnt. Thanks.
brian schuetta is offline   Reply With Quote
Old 11-22-2017, 11:19 AM   #2
Dave1695
Liked 15 Times in 11 Posts
Default Re: Testing Line Pressure TH-350
Right side of case (passenger side), near tail housing; there is a hex head 1/4 npt plug.
Dave1695 is offline   Reply With Quote
Old 11-22-2017, 12:00 PM   #3
Liked 5,118 Times in 1,950 Posts
Yes..rear most port, except it is 1/8 npt
Old 11-22-2017, 12:26 PM   #4
brian schuetta
Between the modulator and the servo?
Old 11-22-2017, 12:56 PM   #5
Right side of TH350 case.
Rear port is main line pressure. You will see pressure here in all gears for most valve body configurations. Some race-only valve bodies may not have pressure at this port or the others
Middle port is 2nd gear pressure
Front port is third gear pressure
Old 11-22-2017, 03:13 PM   #6
Eman
Liked 133 Times in 76 Posts
http://www.crankshaftcoalition.com/w...0_rebuild_tech
Scroll down for pic of the ports.
Eman is online now   Reply With Quote
Old 11-22-2017, 05:24 PM   #7
1720
1720's Avatar
Liked 2 Times in 1 Post
Right side of TH350 case. Pressure ports are circled.
  • Rear port (yellow) is main line pressure. You will see pressure here in all gears for most valve body configurations. Some race-only valve bodies may not have pressure at this port or the others
  • Middle port (red) is 2nd gear pressure
  • Front port (blue) is third gear pressure
TH350 pressure ports circled
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
