Old 10-19-2017, 08:59 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Approved Carb
How do you know if your combo has one? Is it in the blueprint or the aftermarket approved parts pdf? Are there any listed for SBF and FE motors? I thought the 302 was allowed a quickfuel but don't see that either. Thanks.
'65 Mustang SS/L & L/SA
Old 10-19-2017, 11:47 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Approved Carb
You need to call QuickFuel (now Holley, again). There are a lot of approved carb numbers that aren't on any published NHRA lists. You are probably looking at the 585 vs to replace a Holley for SBF. On the Holley/QF catalogue page is the following:
"585 CFM QuickSel'" vacuum secondary for Stock and Super Stock; replacement for Holley" 1.250" primary, 1.313" secondary venturi 1 9/16" throttle bore Replaces list numbers: 2818, 3043, 3139, 3140, 3245, 3367, 3419, 3420, 3530,3557, 3793,3795,3796,3806,3810,3811, 3814,3815, 3807,3836,3837,3838,3839,4088"
Hope this helps. I went through the same thing.
Dale Shearon
68 Mustang 6394
Old 10-19-2017, 11:47 AM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I think the blueprint specs list the "authorized replacement" carbs for each engine combination, Bobby. The accepted products list aftermarket units that have been approved for certain combinations. If you notice there are venturi and throttle-bore sizes listed in the blueprint specs, so if, for example, you had a later model Motorcraft carb with the same specs as the one listed for your vehicle you are allowed to use it. The Quickfuel carbs that were approved as replacements for OE Holley's fit about 99% of the combinations out there, but I'm unfortunately still a 1%er, the smallest they have is a 585 CFM!!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 10-19-2017, 12:17 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I looked back at my old carbed combo, and all that is listed is venturi and TB size. I guess anything goes, as long as those two dimensions are correct!
Sean Marconette
84 Mustang
5060 SS/N
Old 10-19-2017, 12:37 PM   #5
Ven302
Ven302's Avatar
Liked 34 Times in 7 Posts
I asked specifically about the 1968 302 w Holley and was told NO the quick fuel is not a legal replacement. WAS 2 years ago. We bought the right core and blueprinted it. FYI
I guess the phone call would be worth it on this one.
VENICE PERNO
SS/CS 3041
NHRA SUPERSTOCK
Ven302 is offline   Reply With Quote
Old 10-19-2017, 03:24 PM   #6
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
The 1985 302 has a QF legal for that combo
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is online now   Reply With Quote
