Old 09-15-2017, 01:52 PM   #41
600ci
Liked 3 Times in 1 Post
Cool Re: New Rule Revision For Stock and S/S
Originally Posted by Travis Miller View Post
On www.nhraracer.com a new rule revision for Stock and S/S dated 9/12/2017 has been posted.
The old rule read...Driver and passenger-side seats must be identical in appearance.
The new rule reads as follows:
If a full-sized corporate OEM driver’s seat is used, the passenger seat must be identical in appearance to the driver’s seat. If a full-sized aftermarket driver’s seat is used the passenger seat must be full-sized and identical in appearance to the driver’s seat being used or must be a full-sized corporate OEM passenger-seat.
That means an aftermarket passenger seat cannot be drilled full of lightening holes or have the upper portion/head rest cut off. Its time for a few racers to buy a new passenger seat because they butchered the seat.
new nhra rule all drivers must have a minimum of 20%hair on there body
no shaved heads and torso. for weight advantage
600ci is offline   Reply With Quote
Old 09-15-2017, 02:08 PM   #42
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Default Re: New Rule Revision For Stock and S/S
No Problem, but what if your head is naturally bald? Do I have to ad weight to compensate?
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 09-15-2017, 02:11 PM   #43
SSDiv6
Steve, there is an exemption for bald Canadians....
Old 09-15-2017, 05:33 PM   #44
Coleydog
Liked 53 Times in 38 Posts
My personal opinion, after seeing the outcome of bruises and injuries on other racers that have experienced accidents, and taking in to account the current speeds, I will not go low cost, or use a fiberglass or metal seat with just a cover, or compromise because visibility on a racing seat.
In my new Comp car, I am using an FIA approved seat, with support and cushioning to protect my body in the event of an accident and also allows me the use of a HANS device.
Yes, they are expensive when compared to an aluminum Kirkey, nevertheless, I will never compromise my safety.
The two brands I recommend are Cobra and Racetech.
For the passenger seat, I purchased an Ebay, Chinese made, racing seat that looks identical to my FIA approved seat and it only cost me $75.00.
Below is the Cobra seat I am using and next is the Racetech seat used by many in their drag cars.
While some seats are better than factory what saves you are the properly attached and tightened seat belts. Plenty of studies on this.
Old 09-15-2017, 05:54 PM   #45
SSDiv6
Any FIA approved racing seat will be a better design than an OEM for racing. The reason why the Drag Paks have Dodge Viper seats, the COPO cars have Sparco seats and the Cobra Jets have Recaro seats.
It must be assumed that anyone that races, would be aware to make sure their seat belts are properly anchored and tight, and as usual, there are exceptions...
I have heard of racers that leave their seat belts loose so they can turn their heads and be able to look at he other lane, putting themselves and others at risk.
Old 09-15-2017, 05:59 PM   #46
carbuilder
Liked 19 Times in 5 Posts
Another reason to shorten pass seat height, obviously no performance advantage, safer operation is all I see,,,, how much weight do you think shortening a aluminium seat gais you,,,, less than a pound for sure
carbuilder is offline   Reply With Quote
Old 09-15-2017, 07:50 PM   #47
SSDiv6
Lost you at "safer operation".
So what you are saying is if they allow shortening the seats, then the drivers will tighten up their seat belts? Oh Boy!
Old 09-15-2017, 08:04 PM   #48
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Other than the drivers not having the proper safety equipment on for the ET`s they`re running, this whole thread is a joke.
Lane Weber
Old 09-15-2017, 08:32 PM   #49
600ci
those with edsel jets
Old 09-15-2017, 08:45 PM   #50
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
This thread was not meant to be a joke. I originally posted it to give racers a heads up about the new rule revision that had to do with Stock and S/S interiors. But I see that was a waste of time so in the future instead of letting racers know about something that will effect them, I guess they will have to find out on their own. And I will not take up any more of your time.
Travis Miller is offline   Reply With Quote
