#51 | |
What I was stating is the air cleaner assembly is not the reason why the car is fast. It goes fast because the hard work put not only on the engine, but also the car. This particular air cleaner assembly does not have a ram air effect; it draws air from the bottom of the air cleaner. Even my son's V6, 1997 Firebird had this air cleaner assembly. |
#52 |
Liked 80 Times in 29 Posts
Like many, it goes fast because it was not factored correctly and the system that's in place to do so is not allowed to work as intended.
With the respect due fellow racers, what's wrong with factoring cars prudently commensurate with true performance capability? |
#53 |
Liked 974 Times in 310 Posts
Put in a 5 speed manual and all is well.................and fun!
#54 | |
Liked 312 Times in 175 Posts
#55 |
It's the "holding" and protection of the combination that causes this dilemma.
In fairness and for the respect of competition, what's wrong with accurate factors based on actual performance capability? Those that aren't willing to apply the effort and invest the time won't compete favorably in any case. Last edited by Paradigm Shift; 06-14-2017 at 07:27 PM. |
#56 |
Liked 8,115 Times in 1,531 Posts
A little interesting tidbit is that 1983 Camaro coupe is still factored at 263 HP.....
#57 |
I thought I might make a couple of points here.
This is not meant to knock anybody .(Okay, maybe NHRA) .I've known Kenny for a long time . He helped me build a S/S Chevy II station wagon, over 40 years ago. He certainly has paid his dues, both literally and figuratively. * Jeff Stout told you what's supposed to happen if you show up with an F.I. air inlet duct in front of a 4 bbl. carb engine. That alone is a good reason to have knowledgeable tech guys look at every car, every race. * I always thought you supposed to take everything off of the front end of a drag car , that wasn't needed, no matter how small or light. ;-)
#58 |
If Tech says you need the body pcs. to present your Camaro as a Z28, like hood, ground effects, spoiler, etc. and of course your min. weight is different than a plain Camaro then that air inlet should be on the car. You can't suck and blow at the same time. Hey that's 2/3's of a pun, pu
#59 |
Liked 2,746 Times in 969 Posts
In a perfect NHRA tech environment, there would be proper technical inspections performed by dedicated and knowledgeable personnel with the resources necessary to enforce the rule book, and back in Glendora and the Divisional offices there would be a knowledgeable staff to closely monitor performance, factoring and technical standards.
At one time all this existed, but it will never happen again, the NHRA won't fund it because it's no longer important to them. They've made a business decision. Just an observation, not a criticism. |
#60 | |
