Old 05-31-2017, 11:30 AM   #11
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: Nhra releases 2017 rule book amendments
Shifting should be a function of the driver. No assisting devices whatsoever. The same for everybody. Just my .02
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-31-2017, 12:25 PM   #12
Bobby Fazio
Bobby Fazio's Avatar
If you need assistance shifting a 2 or 3 speed automatic you probably shouldn't be racing. Now when is Elegal-shift going away in stock?
'65 Mustang SS/L & L/SA
Old 05-31-2017, 12:33 PM   #13
Bobby DiDomenico
Liked 101 Times in 52 Posts
Ed,
We could never figure out how or why they ever let some automatic cars have an electronic 1-2 shift.
Old 05-31-2017, 12:55 PM   #14
novassdude
Liked 136 Times in 49 Posts
By the name automatic transmission it should not take any function of the driver or it would be a manual transmission.
A true automatic you just put it in drive and go.
novassdude is offline   Reply With Quote
Old 05-31-2017, 01:29 PM   #15
Liked 5,109 Times in 1,947 Posts
Let's not get too carried away here. Governors in automatics were OEM items, long before TA or ratchet shifters were around.
Old 05-31-2017, 01:47 PM   #16
Carguy49
Liked 2,923 Times in 702 Posts
Mark, since you work with automatics all the time, I have a question for you. Is there a limit as to when an automatic trans can be made to shift by itself?
Ron McDowell - Did Race
Old 05-31-2017, 02:12 PM   #17
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Most governors , or auto 1-2 shifts are based on output shaft rpm . Electronic shifts are based on engine speed . The difference is on good weather days a governor shift will appear to shift at a higher rpm , due to converter slip . Electronic shifts will shift at the same rpm regardless of the weather . Might be a problem trying to dial in a car if the weather changes during eliminations .
Old 05-31-2017, 04:33 PM   #18
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
I bracket raced an automatic for years and tuned the shift points with the governor.
Just put it in D ....and it worked fantastic... shifted dead on every time on target.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-31-2017, 04:36 PM   #19
ALMACK
ALMACK's Avatar
My IHRA Pure Stocker has the electronic auto and after I installed the Baumann shift kit, it automatically shifts dead on @ 5,300 every pass, every gear
I/PS '95 Mustang GT
Old 05-31-2017, 05:18 PM   #20
ss3011
ss3011's Avatar
Does your transmission have a governor ? When I raced Pure Stock we had to run the stock 13" converter , which was pretty tight , so there was not much slip in the converter at the shift point . Has the Pure Stock rules been changed , so it allows a loose converter ?
