#11 |
Liked 520 Times in 132 Posts
Shifting should be a function of the driver. No assisting devices whatsoever. The same for everybody. Just my .02
#12 |
Liked 4,389 Times in 505 Posts
If you need assistance shifting a 2 or 3 speed automatic you probably shouldn't be racing. Now when is Elegal-shift going away in stock?
#13 |
Liked 104 Times in 53 Posts
#14 | |
Liked 136 Times in 49 Posts
A true automatic you just put it in drive and go. |
#15 |
Liked 5,153 Times in 1,967 Posts
Let's not get too carried away here. Governors in automatics were OEM items, long before TA or ratchet shifters were around.
#16 |
Liked 3,026 Times in 725 Posts
Mark, since you work with automatics all the time, I have a question for you. Is there a limit as to when an automatic trans can be made to shift by itself?
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
#17 |
Liked 239 Times in 114 Posts
Most governors , or auto 1-2 shifts are based on output shaft rpm . Electronic shifts are based on engine speed . The difference is on good weather days a governor shift will appear to shift at a higher rpm , due to converter slip . Electronic shifts will shift at the same rpm regardless of the weather . Might be a problem trying to dial in a car if the weather changes during eliminations .
#18 | |
Liked 373 Times in 131 Posts
Just put it in D ....and it worked fantastic... shifted dead on every time on target.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#19 | |
#20 |
Does your transmission have a governor ? When I raced Pure Stock we had to run the stock 13" converter , which was pretty tight , so there was not much slip in the converter at the shift point . Has the Pure Stock rules been changed , so it allows a loose converter ?
