Old 03-27-2017, 10:52 AM   #11
Greg Reimer 7376
Liked 704 Times in 218 Posts
Cool Re: 5.3 LS Top End Noise
Seems to me with a quarter million miles on it, the expeditious thing to do would be to replace the cam,lifters,pushrods and rocker arms. If one or two parts are worn beyond the valve train's ability to compensate for itself, the rest can't be too far behind. I'm sure that engine would have a steel roller camshaft as well. It probably wouldn't go flat and put shrapnel throughout everything, it probably would just wear down smoothly,but that and a new timing chain and gear set would probably set you right up.Who do you suppose has the record for the most miles on an original engine?
Old 03-27-2017, 01:55 PM   #12
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Default Re: 5.3 LS Top End Noise
If this is an 07 model new body style, it could very well be a lifter problem. If it is an 07 it should have active fuel management which disables 4 cylinders to supposedly decrease fuel consumption. These lifters are prone to failing and causing problems. Eventually, it will result in camshaft wear. If it is not a new body style 07, then it would more than likely be a lifter issue. If the noise is mainly when it's cold, it is very likely that a lifter is just getting weak and it bleeds down when sitting.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 03-27-2017, 03:36 PM   #13
brian schuetta
Liked 28 Times in 15 Posts
It's the Classic body style. Lots of chassis parts on this thing like calipers and hubs are 06'pieces. No AFM. There is another Classic body style truck on this job site, an 02'with 297K on it. The truck has been good to me. Still have the original exhaust, starter, alternator, and trans.
brian schuetta is offline   Reply With Quote
Old 03-28-2017, 12:12 PM   #14
Doug Blackley
Doug Blackley's Avatar
Had that same noise on my '01 Suburban with the 5.3. Had a leaking head gasket as well so while heads were off I replaced all 16 lifters. That was 5 or years ago at around 185k give or take. Now at 222k noise has never returned.
Doug Blackley 1697 STK
Old 03-28-2017, 02:20 PM   #15
FED 387
Liked 330 Times in 178 Posts
For whatever it's worth Melling lists 2 pumps for that engine M295 and M295HV. The HV pump flows 18% more oil and is recommended for high mileage vehicles to quiet valve train noise. Might try that before you tear into doing lifters etc not saying it will solve your problems but a lot easier than pulling the intake etc---Fed 387
Old 03-28-2017, 09:35 PM   #16
TommyPettigrew3076
Liked 26 Times in 11 Posts
Are you sure it isn't an exhaust leak ? These motors are known to for the manifold bolts to break of mostly on the very back . I had this same problem chased it lifters , flushed , different oils turns out that is what it is they even make a kit to fix the problem I found through a buddy of mine that had the same problem I will try and find the
linkhttp://kralautoparts.com/product/exhaust-manifold-bolt-repair-kit-kap169
TommyPettigrew3076 is offline   Reply With Quote
Old 03-29-2017, 08:56 AM   #17
brian schuetta
Will look into the exhaust leak potential. Haven't heard the noise in a couple days, which is a good thing, unless you are trying to find out more about the problem. I'm trying to look at all the possible causes for this before I do anything too involved. Thanks for all the input guys.
Old 03-29-2017, 09:06 AM   #18
John Kissel
Liked 230 Times in 94 Posts
Brian, Take a look at Dorman #917-107 & #917-142 exhaust manifold clamps, they do work.John Kissel
John Kissel is offline   Reply With Quote
Old 03-29-2017, 11:37 AM   #19
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by brian schuetta View Post
After not hearing it all weekend it came back briefly this morning when was still cold. No noise when I stopped for gas. BTW turned 249K this morning. So first thing this morning I will figure out which rocker/lifter/valve is making the noise, if it does it again, and then try some of the "fixes"mentioned. Still going to buy valve cover gaskets in case we have to pull a cover.
Have same issue with my 94 Caprice wagon with a 240,000 mile LT1.
Idles smooth as glass in gear but stumbly in Neutral.
Replaced parts and went through every electrical and fuel system.
Between 3000 and 4500 rpm pulls but there are funny sounds.
Feels and sounds like rocker/valve noise.
Pulling the Valve covers ..nothing!
Rebuilt LT1 being prepared by Rockville Ring & Bearing.
Upgrading to a PerformaBuilt HD 4L60E OTW !
If this one does not live time for a 6L80E.
Dan
Old 03-29-2017, 03:43 PM   #20
Irace007
Liked 17 Times in 12 Posts
Check all the ex manifold bolts #7/8 are usually the culprit.We've done some of the HV oil pumps and they do work.Have seen a ton of bad lifters/rockers.(Noise is most noticeable on cold starts.)
former GM tech...good luck
Marty
Marty Hanft
Irace007 is offline   Reply With Quote
