Old 03-25-2017, 09:12 AM   #1
428tom
Default Small block ford crank scraper
Looking for information on Pros or cons for running a crank scraper in a small block Ford and also which would be the best one to run
428tom is offline   Reply With Quote
Old 03-25-2017, 09:27 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Small block ford crank scraper
I've had improvements in oil control and some modest power increases on the stock pan AMC's I build using scrapers.
These guys offer a scraper for almost any engine and the rough fit is very close. only minor trimming is needed.http://www.crank-scrapers.com/index.html
Old 03-25-2017, 02:24 PM   #3
SSDiv6
Like Tom Goldman said, the crank scrapers from the company shown in the link are well engineered and designed for each engine and specific application.
Old 03-26-2017, 11:10 AM   #4
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
My experience with crankscrapers.com is don't waste your time. Ordered one, was told it was special order. Had to pay up front for it. Understand that, but got a lot of promises, completion dates, tracking numbers and after a year got a refund.
Patric Fox is offline   Reply With Quote
Old 03-26-2017, 11:43 AM   #5
fordteacherguy
Liked 160 Times in 51 Posts
I run a Canton in my motors:There might be better ..but these work fine for me.
https://www.summitracing.com/parts/ctr-20-830
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 03-26-2017, 01:22 PM   #6
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Who makes one for a 351C ?
Dave Noll, EF/S ,?/SA 6526
Old 03-26-2017, 01:54 PM   #7
428tom
https://www.summitracing.com/parts/ctr-20-830/overview/
Do you run a windage tray with the crank scraper?
Old 03-26-2017, 06:04 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
What block are we talking about? I don't have a crank scraper but I do have a windage tray on my Ford Racing M6090BOSS 302 block. Had to use a bolt kit for a 351 due to the 1/2 inch main bolts on this block.
Dale Shearon
68 Mustang 6394
Old 03-26-2017, 06:28 PM   #9
fordteacherguy
I do run a windage tray also. Milodon is a budget one that does ok for the RPM of my stocker.https://www.summitracing.com/parts/mil-32212
Brian Thompson
Old 03-26-2017, 07:31 PM   #10
fordteacherguy
MPG and others...shop around.
http://www.mpgheads.com/black_max.php
Brian Thompson
