Old 02-27-2017, 01:08 PM   #1
sskwb
Default 360 magnum heads
Hi all,
i am newish to class racing and very new to this combo
Of the heads listed below considering the extra weight they may be carried. what is the head of choice for a 360 Dakota stock elim truck and who is the preferred head/ valve job person for the magnum heads.
all opinions positive or other wise appreciated
thank you for your help in advance
Kurt Bastian
Cylinder Heads:
53006671
53020466
Edelbrock aluminum 61767
MoPar Performance P5007140. discontinued but can be found
MoPar Performance P5155469
sskwb is offline   Reply With Quote
Old 02-27-2017, 07:15 PM   #2
magnumv8
Default Re: 360 magnum heads
Dakotas are very front end heavy so anything that can remove weight is
a benefit...that being said since NHRA had Edelbrock make the "767"
head legal that is the way to go....now unless things have changed (I
doubt it) you will need to sleeve the guides down to 8 mm since the
Edelbrock head comes with 11/32 guides.....pm me if you want more info
D L Rambo.....Stk 1300
magnumv8 is offline   Reply With Quote
