What is the required carburetor for the 305/175 hp engine 85 Camaro (H/SA)? Any aftermarket carbs that are legal? Any recommendations on a good carb? Thanks, Jason
Liked 249 Times in 48 Posts
Check Dwight's site www.classracerinfo.com.
Register and then use the technical tools section. Should tell you what you need to know. Remember that you can use any carburetor of the same type and size. It does not need to be of the correct year. Pete |
Liked 28 Times in 9 Posts
You will save yourself some time and the possibility of a bad decision by calling Dean Oliver ( Deano's Carburetors) .He will set you straight !
