Old 12-30-2016, 01:32 PM   #1
BZenzen
BZenzen's Avatar
Liked 474 Times in 83 Posts
Default Rossler Powerglide
Rossler Powerglide / Shifter Setup For Sale:
SFI certified Dedenbear case (no need for a shield)
2.08 Low Gear (3 seasons since replaced)
2 seasons on new ATI Drum/Band
55 Runs since serviced and freshened this spring
Deep Moroso Pan
Rossler Trans Brake
Forward valve body
Turbo Action Forward Pattern 2 Speed Shifter(3 Speed adaptable with removing a tab)
Shifter has line lock button attached
Dedenbear RPM Shift Module for 1-2 shift
Dedenbear Electric Shift Solenoid
Everything you need to drop the trans, shifter, and module in the car and go racing!
Make Offer! New setup is in the car, no reasonable offer will be refused!
Call Ron at 320-248-5402
Brian Zenzen
SS 5404
STK 5401
BZenzen is offline   Reply With Quote
