Old 12-27-2016, 10:12 AM   #1
randy wilson
Liked 22 Times in 22 Posts
Default 10 degree GM wedge heads
What's the part number to the 10 degree small block head, and where do you get them?
don,t have one
Old 12-27-2016, 12:16 PM   #2
Ron Miller
Liked 13 Times in 7 Posts
Default Re: 10 degree GM wedge heads
25500141 – Buick or Chevy aluminum, 10 degree race head, 42cc chambers, symmetrical ports, 235cc intake ports, 2.1/1.625 valves
Ron Miller is offline   Reply With Quote
Old 12-27-2016, 12:20 PM   #3
randy wilson
Thanks, but not the Dart Buick. I have 3 sets of those. Some got ahold of them early when they first came out, and one well know comp SS racer told us they're hard to get but well worth it. He said they were .15 to .2 better then the 615 15 degree head.
don,t have one
Old 12-28-2016, 07:37 PM   #4
Woodfin
Liked 288 Times in 109 Posts
Randy, check over at the website "the comp buzz"
Woodfin is online now   Reply With Quote
Old 12-28-2016, 10:43 PM   #5
randy wilson
Thanks. It may be bogus, I've checked on GM performance and none are listed, but I've seen one set on a top car, and I see CFE builds an intake for them, but they must be a figment of my imagination. I will check though.
don,t have one
Old 01-04-2017, 04:18 PM   #6
Mike Mans
Liked 299 Times in 48 Posts
I have always been under the impression that CFE and SLAWKO are the only two that have really rolled the 615 castings over to 10*. I'm guessing some welding has taken place to allow that to happen, but I know it was never a GM casting that started at 10*.
Mike Mans
Mike Mans is offline   Reply With Quote
Old 01-04-2017, 04:45 PM   #7
randy wilson
Mike Mans
Thank you. That explains a lot. I've searched and about the only company that casts any are MBE for 4 cylinder midget racing that fit a small block Chevrolet. Thanks again.
don,t have one
Old 01-08-2017, 10:51 PM   #8
Mike Mans
Randy - I sent you a PM as well.
Thanks - Mike
Old 01-08-2017, 11:37 PM   #9
SSDiv6
Mike Mans
Mike, you are correct.
The 615x cylinder head as cast, can be rolled to 12 degrees. To achieve 10 degrees, a lot of more worked is required.
Old 01-09-2017, 12:02 AM   #10
SSDiv6
By the way, Carl Foltz, owner of CFE, some time ago, made his own version of the 615x cylinder head.
http://www.cferacing.com/?pid=21
