Old 12-17-2016, 03:02 PM   #1
jimmyparker
Liked 309 Times in 88 Posts
Default classic dominator siding screws
Attempting to replace fenders on a Classic Dominator trailer and found the screws to be in between 1.5 and 2.0 torx bits, I have several sets of bits and nothing between these two sizes nor does McMaster Carr supply show anything in the middle. Any ideas?
Thanks
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 12-17-2016, 03:30 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: classic dominator siding screws
Jimmy the screws on both of my Classic trailers have been double square. Square bits work fine, sorry but cant remember what they call the size.
Painter is offline   Reply With Quote
Old 12-17-2016, 04:03 PM   #3
FED 387
Liked 335 Times in 182 Posts
They're are called Robertson. Find them in the home improvement centers H Depot- Lowes etc.
Old 12-17-2016, 10:28 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
It is not a torx bit, I have a classic trailer and as the other guys have pointed out a square bit is all you need. In the hardware store like HD, deck screws have single square heads. That is the bit that you need.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-18-2016, 01:13 PM   #5
jimmyparker
Thanks for the help, a #2 square did the job although it didn't make sense to me!!
Old 12-18-2016, 01:53 PM   #6
FED 387
They use that style of drive because you can drive the screw in from an odd angle and also they do not strip out the square drive area like a Phillips drive will. FES 387
Old 12-18-2016, 01:59 PM   #7
Hacksaw
Liked 314 Times in 177 Posts
That screw head was designed by a Canadian named Robertson somewhere in the 1950's. Four sizes matched to a colour. Smallest being yellow, then green, red and black. Never got popular in the States but they really work well, stay on the end of your driver bit and don't strip easily.
Old 12-18-2016, 05:06 PM   #8
Painter
We saw a lot of them in the marine industry in late 50s and the sixtys. Good fastener, lots better than a phillips. Still see them a lot in the electrical industry.
Old 12-21-2016, 12:15 PM   #9
340Cuda
Liked 805 Times in 341 Posts
Does anyone know where the screws can be purchased? A few of mine have rusted for some reason and it would be nice to match the rest of them.
Thanks,
Bill
Old 12-21-2016, 12:57 PM   #10
FED 387
McMaster Carr sells them they are listed as PAN HEAD SQUARE DRIVE screws ---lots of diameters and lengths as well as material zinc coated/stainless steel etc. to choose from--- come in pkgs of 100---FED 387
