Old 12-07-2016, 09:22 PM   #41
sammy pizzolato
Liked 56 Times in 13 Posts
Send a message via AIM to sammy pizzolato
Default Re: Lifter rule in Stock
This new rule is smart for us Racers that have lost good motors to those JUNK Ceramic Lifters!!!! and for NHRA to check cams.
sammy pizzolato is offline   Reply With Quote
Old 12-07-2016, 10:30 PM   #42
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by jimi View Post
been using solid lifters on hydraulic cam grinds for years in street cars adjust the lash at.006".
Could have a Max Spring Rule instead!
Simpler..
D
Old 12-07-2016, 11:10 PM   #43
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I'm going to keep my hyd. lifters, solids would be a lot noisier and then I would have to keep them adjusted, and that might..............would cut into my adult beverage time.
X2 on that Larry!!
By the way, since lift will be checked at zero lash but you wouldn't run a solid at zero lash, I assume you have to give up some lift if you change over.
Mike Moller
NHRA 203 Q-R-T/SA
Old 12-07-2016, 11:31 PM   #44
Wink Re: Lifter rule in Stock
Originally Posted by MikeMoller View Post
X2 on that Larry!!
Yes, but I don't think you need .006. A lot of older motorcycle exhausts were around .003.
Somebody try and let us know ....
Old 12-08-2016, 12:34 AM   #45
killintime6968
Liked 91 Times in 29 Posts
Please excuse my ignorance. But does this mean we can now run a solid lifter type cam in a hydraulic cam engine. IE a 396 350hp. Or just solid lifters on the hydraulic cam.
Bruce Cameron
1969 Nova E/S
1968 Camaro SS/I
killintime6968 is offline   Reply With Quote
Old 12-08-2016, 01:52 AM   #46
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Since any duration is allowed I don't see why someone couldn't grind slight clearance ramps (just a couple thou) into them, but it doesn't seem worth bothering with.
Dave Muller is offline   Reply With Quote
Old 12-08-2016, 09:11 AM   #47
Liked 1,919 Times in 432 Posts
Originally Posted by Rick Schilling View Post
I know this should be obvious, but if your combination already uses hydraulic roller lifters you can convert to solid rollers now?
If that is the case, then a lot of stockers are about to gain a lot of RPM, and spend a lot of money. This could get really interesting. Or really stupid. Maybe both.
Old 12-08-2016, 09:28 AM   #48
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Alan, that usually goes hand in hand. It's like the chicken and egg thing.
Old 12-08-2016, 09:44 AM   #49
Alan Nyhus
Liked 800 Times in 237 Posts
Yes, but I don't think you need .006. A lot of older motorcycle exhausts were around .003. Somebody try and let us know ....
Mark, this has been done for decades on high perf street engines.
You can be down around .002 (hot) with a solid lifter on a 'hydraulic' cam lobe. Basically, as close to '0' as you can without hanging the valves open. A good rule of thumb.... on a typical iron head/iron block setup, you need around .003 more lash 'cold' than what you want it at 'hot' to allow for expansion. ie: .006 cold will get you .003 hot.
Iron block/alum. heads & alum. block/alum. heads expand differently than iron block/iron head, of course.
"That'll never work....."
Old 12-08-2016, 10:07 AM   #50
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
I just emailed NHRA Tech to get clarification on the new language. This is the response:
"The intent was/is to allow the use of a solid lifter in place of a hydraulic, you may not replace a flat tappet with a roller.
Thanks
Joey Gorman
NHRA Assistant Regional Technical Director
Office-(317)-969-8609"
...and there you have it.
Here we go. Why do the hyd cam combos get an "up grade" and not the solid cam combinations?? IF ( I am not advocating for this) everyone had been up graded to rollers would that not have leveled the playing field? Am I missing something here? Are not the lifter concerns "wiping out a motor" shared with solid and hyd cams?
Phil Vos
Grey Ghost is offline   Reply With Quote
