Old 11-23-2016, 12:19 PM   #1
parkdale
Smile WTB Turbo Action shifter gate
anyone got a forward pattern gate for a Turbo Action shifter , some how i ended up with two wrong ones .
parkdale is offline   Reply With Quote
Old 11-23-2016, 01:43 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Default Re: WTB Turbo Action shifter gate
For Mopar yes....if that helps.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-23-2016, 07:55 PM   #3
Mike Savelle
Liked 7 Times in 5 Posts
any one know if a mopar forward pattern work on a GM shifter ?
Mike Savelle is offline   Reply With Quote
Old 11-27-2016, 08:04 PM   #4
Dave Crysler
If you have a reverse pattern gate for a GM shifter I will trade for a forward pattern. Mike, I went to Paul's site, the gate length between park and reverse is 1 inch on gm gate and a half inch on Chrysler gate. The forward pattern gate I have is for a gm. You may want to go to the turbo action site and see what gate you need for your shifter to function properly. I need a 70073b so my shifter moves to the right on 1-2 shift.
Last edited by Dave Crysler; 11-28-2016 at 08:00 PM. Reason: answer a question and state my item for trade.
Dave Crysler is offline   Reply With Quote
Old 11-29-2016, 04:56 PM   #5
540gtx
I've got a forward pattern for a T400, I'll dig it up
Kevin
540gtx is offline   Reply With Quote
Old 12-01-2016, 01:33 PM   #6
Mike Savelle
Dave Crysler all my reverse gates move the shifter to the right . I sent you a PM
Old 12-01-2016, 05:20 PM   #7
Coleydog
Liked 53 Times in 38 Posts
The two Mopar ones I have will work either way, just have to pull over for high on reverse pattern. Maybe these are just forward patterns, ? been used that way for 30 years.
Old 12-01-2016, 08:20 PM   #8
Dave Crysler
Here's the thing Mike, I'm poor, I was hoping to trade for a gate I could use if I am ever even able to race again. The measurements I posted tell me that the shifter may not work properly if gates from different models of shifters are swapped. It doesn't really matter because the person that made the inquiry has not even responded.
Old 12-02-2016, 08:46 AM   #9
Mike Savelle
Dave I am the person that inquired I sometime use my work pc. how wide is the stop between park and reverse , 3/4 ,1/2 or 1 "
Old 12-02-2016, 04:08 PM   #10
Dave Crysler
1 inch
