Liked 9 Times in 4 Posts
Why is it legal in Stock for a COPO to have an air shifter?
Liked 7 Times in 5 Posts
because nhra wants copos in the lanes
Liked 93 Times in 52 Posts
Per rules: Pneumatic, hydraulic, electric, etc.controls and shifters in all noncomputer-controlled electronic-fuelinjected vehicles prohibited.
Makes a lot of sense
Liked 502 Times in 130 Posts
Its legal? Do you have a picture of a stocker with an air shifter? That just doesn't sound right. E-shift 1-2 is legal, but an air shifter is a totally different animal. At least the fateful 2-3 shift must be done by hand.......I will be looking the next time I am in the staging lanes!
Eric Merryfield 1883 STK |
Liked 70 Times in 31 Posts
I believe because they came from the factory that way.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
[QUOTE=Darrel Goheen;517953]I believe because they came from the factory that way.[/QUOTE
There was a time when NHRA told the factory what was acceptable and what was not. Guess those days are long gone. |
Liked 237 Times in 126 Posts
The transmission section of Stock is a bit muddy on this. It seems that an rpm activated electric shift unit "internal or external to the transmission" can be used on a computer controlled car. The solenoid on one of these looks like a CO2 unit but is shorter.
Air and electric shifters and controls are prohibited on all "non computer controlled EFI cars" Nothing about carburetor cars noted.
Liked 136 Times in 49 Posts
There is a provision for having an Air/solenoid activated shifter. I have a letter from NHRA that states I can have an electric solenoid on my shifter but it must be activated by the driver not a timer or rpm switch. So I have a button on my hand controls to activate the solenoid and change gears. I have not looked at the rule book lately but I thought they had a provision in it for a situation like this.
Good chance this is not the situation in the COPO case but it is possible. |
Liked 43 Times in 9 Posts
My opinion is that if a guy in an EFI car (2000 Firebird for example) chooses to run his 4L60E computer controlled transmission through his ECU, more power to him! But when you need an electric or pneumatic add on gizmo and a stand alone box in a Metric 200 to do the shifting, it shouldn't be legal. Or give everyone the same stuff. (Not my choice)
Stock is more and more becoming a far cry from what it once was.... Obviously in novassdude's situation things can be made to work. As long as it's a function of the driver. Last edited by Mark Faul; 10-19-2016 at 12:28 PM. Reason: Add |
