Old 09-06-2016, 10:14 PM   #1
Steve Ficacci 1142
Default 327, clutches, shocks, bellhousing, trans, ignition....
327 shortblock, 3892657 block, ATI balancer, Charlies oil pan, Ross 99578 piston, needs freshening, SOLD
McLeod Clutch (used), GM crank, 153 tooth, aluminum flywheel, Chrysler input, 29 pounds total, disk measures .257 $900
McLeod Clutch missing disk, for rebuild, lightened aluminum flywheel, 168 tooth. $600
Dynamic Convertor, 350 input, 6100 stall behind small block SS motor. SOLD
Lakewood Bellhousing, for chevy, (used) SOLD
Rossler T-350 2.75 first. Auto 1-2. PRN321 - SOLD
Leon Miranian T-350 2.52 first. PRN123 - SOLD
Varishock, double adjustable, bolt on coil over conversion for GM A-Arm, VAS 162M1-425, spherical stem on top, ½ inch ball bushing on bottom. Compressed length 11.4, extended length 14.6, (New). $600
VariShock, double adjustable, eye/bushing on one end, post on shaft end (new), 14 inches compressed, 22 inches extended. $375
QA1 HAL shocks, single adjustable, big end has a bushing, shaft end has a post. 13 inches compressed, 20 inches extended. (used) $125
Crane Hi-7 ignition, Coil, (used) $250
Computech DataPro-45 data logger, Comes with instructions, installation kit, cables, junction box and data logger, never used, SOLD
Computech DataPro-45 junction box, (used), $150
Weld Draglite front wheels with Moroso tires (7.60-15), (used) $325
GM Performance Parts Aluminum Valve Covers, SOLD
Small block, black (new) pn. 141-116
2 axles and C-clip eliminators $225
35 spline, 5 ON 4 3/4", for 12 bolt (used)
ProCar seat, (new) SOLD
SteveFicacci@yahoo.com
973-714-1373
or send me a message on classracer
Steve Ficacci 1142 is offline   Reply With Quote
Old 09-07-2016, 09:28 AM   #2
DMagee
Liked 2 Times in 2 Posts
Default Re: 327, clutches, shocks, bellhousing, trans, ignition....
Interested in the 327...where are u located..?
DMagee is offline   Reply With Quote
Old 09-07-2016, 04:18 PM   #3
Steve Ficacci 1142
Northern NJ
